Question about Sony Xplod XM-554ZR Car Audio Amplifier
Amp wont kick on
I have the power to + and grounded, i dont have rmt tho do i need that, and i only have one fuse on the acutal amp theres 2 slots for fuses tho but my cusin said i only need on and thats the one on the side closet to power and ground.
  • 25 Answers
The amp will not turn on until it receives 12v via the remote turn on. Also, if your amp has two fuse slots, I would make sure they were both filled with the appropriate fuses.
Posted on Jan 08, 2009
  • 27 Answers
You have to instal the remote wire or it will not work. I'd put in the other fuse as well just in case you have the fuse in the wrong slot or it needs both fuses.
Posted on Nov 14, 2008
How to connect wires to amp
Most amps have 3 places where you need to hook up wires to power them. the 1st is a ground wire that at best is 1 foot long and it goes on the ground or negative 12 volt connection then a bolt on the car you may need to sand off the paint for it to work, 2 a RMT or remote wire that is normally in the middle of the power and the ground connections the remote turns the amp on and off so it needs to go to the remote wire on the radio or a ignition spot on the fuse box - turns on with key on and off when you turn the key off , 3 the power wire is hopefully large 4 gauge wire and goes to the + 12 volt plug on the amp this wire has a in line fuse and goes to the battery and to the amp only. RCA wires go from the radio to the amp and are round and just plug in with no screws some factory radios need a conversion kit you can get at walmart for RCA wires. the speaker wires have some sort of mark or line to tell you what to put were like if you put the line on a negative on the amp you need to put the line on the negative on the speaker box to or it will not bass and could hurt your amp. ask me if you need anything else :) and please rate :/
Sep 04, 2012 | Blitz 1600 Watt 4 Gauge Amplifier...
I havea1991 toyota corolla stationwagon that while i disconected the botom ignition harness that is located on the bottom of the key ignition , accidentally grounded the blue whire that has a red stripe ,...
The BLUE/RED wire from your ignition switch provides power to your cigarette lighter and your radio via the 15 Amp "CIG" fuse and the 7.5 Amp "RADIO" fuse in the fuse block under the left end of the dash in the kick panel.
However, this wire will not have any power with the ignition switch removed and therefore would not have been able to blow any fuses with the switch removed. The two fuses that the BLUE/RED wire go to will also not cause your engine to not start.
If your radio does not work and your engine does not start, you probably accidently grounded the WHITE wire. This is one of the TWO power wires going INTO the ignition switch. The other power wire is the BLACK/RED.
The WHITE wire gets power from the 40 Amp "AM1" fuse and the BLACK/RED wire gets power from the 30 Amp "AM2" fuse. Both of these fuses are located in the F.1 fusable link box in the engine compartment at the battery.
Oct 01, 2011 | Cars & Trucks
Nitro 483 amp where do you hook up the power it has a gnd rmt and +12v what hooks up where
Fused 12 volt power wire from the battery connects to +12V at the amp. Chassis ground wire connects to gnd at the amp. Switched 12 volt power wire (accessory) (remote turn on from after market radio) connects to rmt at the amp.
Jan 18, 2011 | Nitro BMW-483 Car Amp
Amp not working
It sounds like you either blew a fuse, or you cooked your amp. The fuse on the P200.2 amp is a 30A fuse, and it sits right next to the power, ground, and remote wire connections on the end. Pull the fuse out and see if it's blown. You should also check any other fuses that you have in the car before the amp.
Mar 03, 2010 | Rockford Fosgate Punch P2002 Car Audio...
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Trying to hook my amp up in my car, I already have everything but the main power supply which is the wire to the battery.I was wondering how would i do that the right way?
the car amp needs to be wired using a +12 power, ground, and +12v signal (rmt) cables.  the +12 volt cable needs to be connected from the posative terminal of the car battery to a fuse (the right size should be written on the amp somewhere) then to the +12v on the amp. the ground cable needs to be connected to the negative terminal of your car battery. the RMT is the more complicated one, this needs to be connected to the header unit or the ignition switch. if you look in the instructions for your header unit (the unict where you insert CD's or tapes etc) this should explain whewre exactly to connect this cable. or you can connect it to the terminal on the ignition switch which becomes live only when you turn the key, should be the third one in. this line basicly tells your amp to turn itself on when it recieves a 12v current. you can also wire it up to a manual switch directly from the battery by connecting another cable to the posative terminal of the battery then to a switch then to the RMT terminal of the amp.
Dec 27, 2008 | Scosche Industries EFX Amplifier Wiring...
No power to pioneer 5300 amp
ur remote wire needs to be hooked up to the spot marked remote on the amp....and ground to the ground slot..if that is done check the fuses on the amp or check the fuse under the hood from your power wireif it still wont come on..make sure ur ground is touching a good metal area sand around the area if needed this should sole ur problem
Jul 27, 2008 | Car Audio & Video
Amp keeps kicking off? Power Protector?
as long as your powers and grounds are good(make very sure your ground is ok) then either you have a intermittent short in one of the subs or the amp is getting ready to die lol.. The sony amps are notorious for faulure-the quality is just not there... Is the amp really hot??? the only other thing you coudl try is to ass a fan or two in it or around it and see if that helps it out..
Aug 18, 2007 | Sony XM-2200GTX Car Audio Amplifier
Amp not turning on
wouldn't be the first JL amp I saw fried...but there are some tests you can do. First of all, double check your fuses, they may appear to be fine, but sometimes they are blown even if you can't see it. Either blindly change them or test them for continuity with a digital multimeter. Also, disconnect the remote turnon and jump power directly over from the power wire to the remote terminal on the amp, if the amp powers on then you have to go double check your remote wire. Hope this helps.
Jul 27, 2007 | Kenwood Excelon KAC-X811D Car Audio...
Amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
59 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
