Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Refridgerator not cooling screen says service EC
We vacumed coils , still not working and screen says the same
  • Joe McG May 11, 2010
    When the EC flashes there is also a number next to it, which corresponds to the actual error code. If the unit is working press and hold the door alarm for 30 seconds to clear it out. If it comes back we can actually start to troubleshot.
    Problem Solver:
  • 8 Answers
Get a Sub-Zero tech out there soon.
Posted on Jan 23, 2009
Refrigerator not cooling properly
There are several things that can cause cooling problem with your refridgerator. The first and most common is dirt dust and lint clogging the condenser coils. These coils are usually located underneath the refridgerator and have a small fan that blows air across them. If they are clogged, the refridgerator cannot get rid of the heat to allow it to cool properly. To check and clean these coils you must first pull out the refridgerator and unplug it. Remove the lower panel ( usually made of a cardboard material) this will give you access to the compressor and fan and coils. Check the coils for dust,dirt and lint. Clean out carefully with a vacuum cleaner or brush( you can get a brush specially made for this ) check the fan motor to see if it spins freely( some units may not have a fan) plug unit in to see if fan runs (make sure to temporarily turn thermostat down colder to turn on compressor and fan). If fan does not come on with compressor you may need to replace it. Put unit back in place and see if that solves the problem. If this does not help, you will probably have to have a appliance repairman check out unit.Hope this helps.
Dec 15, 2013 | Maytag Refrigerators
Tip
Maintaining your refridgerator for longer life
You should clean the back of the refridgerator and vacum it at least one a year, pull it out and clean under it and vacum the back of it, then pull off the cover on the front bottom of the fridge if the coil are underneath, purchase an appliance brush for refridgerators at any hardware store, there not expensive and clean the coils under the fridge, clean in between the black coils and pull out the dust and dirt, then vacum once you get out what you can with the brush, this needs to be done at least once a year for the best perfomance for your fridge and longer life of it......unplug the fridge before you start, the cleaner the coils the cooler the fridge will be and also will use less energy to run......when its dirty it has to work very hard to cool........make sure you unplug the fridge before you start.......hope this helps......
on Jan 06, 2010 | Refrigerators
Hi my refridgerator is not cooling and the fridger section is also not working, every thing is been melted. we can here the refridgerator running but its not cooling.
b44df16.jpgIs the fan motor running below and the coils clean? 8dff5ce.jpg6e3f9f7.jpgIf nothing is running but the light is on you might have a stuck defrost timerb365bb7.jpg
Aug 30, 2010 | Kenmore Refrigerators
My ac unit works sporadically. Today it cooled
First check your filters to make sure they are clean and you have proper airflow.
If they are clean, then you either have low refridgerant or dirty coils.
The outside coils can easily be cleaned by disconnecting power to the unit, then using a water hose to spray off the dirt, grass, etc.
The inside coild can be very difficult to get to on some units and require a special evaporator coil cleaner. As for adding refridgerant, the Law requires one to be certified for purchasing or working with refridgerant so you may need to call a service tech for that. Expect a bill from $100 to $225 for a typical system recharge depending on how low it is and which company you call.
Oct 10, 2009 | Whirlwind FH-778 Air Conditioner
Wont blow cold air
First check and clean the filters, and the evaporator coil. (thats the "inside" coil that has the indoor air sucked through it, cooling it and then pushing it out the vents.
If the filter is clogged or the coils are dirty, it will not cool properly and potentially freeze up.
Also check the condensor (outdoor) coil, if it is dirty/clogged, it will run hot and not cool properly.
If all coils and filters are clean, and the fan motors are running and in good condition and it is still not cooling then you are likely low on refridgerant. (handling/purchasing refridgerant other than R134A requres a CFC certification by law)
Aug 20, 2009 | Heating & Cooling
PAC L90 LT thermostat not working, unit icing over
No that would be either a dirty filter/coil ir low refridgerant if it's freezing in cooling mode.
Clean/replace the filter, clean the coil and if it keeps doing it, have a technician who is EPA certified for servicing systems with refridgerant to look at it/add refridgerant.
Mar 24, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Our alpine air con works but its not cold what could it be
Low refridgerant or dirty coils/filter.
Thats pretty much the only thing that will cause an AC to not cool if all the other mechanical components are working.
Check/change the filter.
Clean the coils/ have them cleaned.
And have the refridgerant levels checked.
Jan 02, 2009 | Heating & Cooling
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Subzero 690 flashing EC and service
Rhino, this is yet another simple fix. You need to call subzero and let them know that your ref section is not cooling properly. 9 out of 10 times it will be a problem with the evaporator coil needing replacement. Sub is aware of this issue and usually picks up the tab for this repair.
Mar 26, 2008 | Sub-Zero 632 / S
If you replace the fan and clean the coils, and the refrigerator STILL does not cool, then contact SubZero or a service provider for an evaporator coil replacement.  Units manufacturer before mid-2003 had copper+aluminum coils that would corrode and allow all of the coolant to escape.  The (should be warranty) replacement is all aluminum.
Note the freezer does not have this issue due to the lack of liquid water.
Feb 20, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
111 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
