Question about MyMusix PD-6070 MP3 Player
The internal media need reformatting
When i turn it on. It says Error: Reformat internal media as FAT16 PD-6070
    Genius:
  • 1,447 Answers
Hi
You need to reformat the player for your computer to recognize it. since its requiring the device to be formatted to FAT16.
Hope this helps
Posted on Nov 15, 2008
    Sergeant:
    Champion:
  • 283 Answers
When you first download your mp3 player, doest it need to have a a driver disk?
If no:
1. connect your mp3 player to your computer
2. open "my computer"
-if dont connect change your usb cable
3. point it to remobale disk then right click
4. select format
If yes:
2. open the program in downloading you mp3 player
3. if recognizes your mp3 player, select restored your player
-if doesnt recgnizes your player change the usb cable.
Post for further information...Please dont rate me if not satisfied with my suggestios..
Thank you for using fixya....
Posted on Nov 16, 2008
  • 83 Answers
Connect it to a windows 98 pc, then reformat it, windows xp / vista doesnt recognize FAT16 as well.
    Genius:
  • 1,913 Answers
Connect with computer then if u found your memory disk then right clik it then format with fat 32
  • kishor khatri
    kishor khatri Nov 15, 2008
    first remove your memory card then also battery if u have then connect with computer then u founrd in my computer then right clik it formst with fat32
  • 113 Answers
Check if the usb cable is connected properly Check that the "Hold" switch on the  off
upgrade ur computer with the latest windows media player even u don wish to use with the player but ur player requires it drivers unistall the dirvers via the device manager u will be able to find under the portable device or under windows portable device once done click on scan for hard ware changes at the top and that will reinstall the drivers automatically
or u can go to this web site  and check how to do firm ware recovery
http://tinyurl.com/5eoy7x
Posted on Nov 14, 2008
    Genius:
  • 1,550 Answers
Regarding computer not recognizing your player .Go to Control Panel and select 'Performance an Maintenance'. Then Select 'System'. Then select the 'Hardware Tab' and select 'Device Manager'. Then find a device called 'Portable Devices' or 'Windows Portable Device'. Then select the + sign next to the device and right click the 'Audio Player'.
Select 'Uninstall'. Click 'OK' when it asks you if it is OK to uninstall. Then select 'Action' at the top of the Window and select 'Scan for hardware changes'. Then once it re-installs the driver, see it operates correctly.
This make your computer recognize the PD-6070.
    Scholar:
  • 69 Answers
the best solution to this problem is to install the software directly from the mymusix site. then when prompted connect the drive.
I noticed that alot of people have this problem and the answer was to get the software at mymusix.com and reinstall
thank you , please don't forget to rate.
  • MyMusix Master
  • 6,487 Answers
Try to connect this player to a different computer and see if it will be detected or not , because if the player was detected on a different computer yuo can now fiormat the player but if still not try first to turn off the unit for about 2 hours then check it again if its still giving you the error...
    Genius:
  • 1,124 Answers
If you can not thru your computer, try with Windows Media Player
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
    Sergeant:
    Champion:
  • 200 Answers
Hi
If ur computer not recogonizes the mp3 player means unplug the player and then connect it again..
Check any virus is their..
If ur player is detected then go to CMD prompt and then give delete..
thank you
    Genius:
  • 1,847 Answers
Plug it into the computer and format it.
  • Legin Varghese
    Legin Varghese Nov 14, 2008
    Once you have plugged in the MyMusix to the computer, go to My Computer and there will be a new drive shown there.
    right click the format the drive.
    hope this will help...let me know the status ...thanks ..kevin.
  • Legin Varghese
    if you have driver disk that came with the player install that, it is very difficult to format with it been recognized by the computer.
3 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: my 1gb pd-6070 mp3
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
-Tha Mp3 Doctor
Posted on May 30, 2008
  • 5 Answers
SOURCE: my 1gb pd-6070 mp3 says
1.Go to the faq by following this link http://mymusix.mmvoice.com/products/audio/PD-6070/faq.html
2. Scroll down until you see Q: How to recover my player's firmware?
3. Follow those instructions.
Worked for me
Posted on Jun 30, 2008
Reformat
connect to your computer and then open "my computer" right click on the player, select properties and then tools. select format and set to fat16, you can also scan for errors from this tab by checking the box.
May 09, 2010 | MyMusix PD-6070 MP3 Player
When I turn it on I get an error message: Error: Reformat internal media as FAT16. If I let the screen go blank then turn it on again holding the button for about 10 seconds it does finally come on. What...
you may need to reformat it according to the computer you are using. If you, just select the drive in my computer(where your hard drive/cdrom/all that **** is) hit format, at the top there will be a drop down menu, click fat16 from there, then select quick format...should fix everything
Apr 01, 2010 | MyMusix PD-6070 MP3 Player
Go to the Mymusix website and download the player update utility (located here: http://mymusix.mmvoice.com/products/audio/PD-6070/software.html )
install it, then use these instructions http://mymusix.mmvoice.com/products/audio/PD-6070/PD6070Vistaonlyfaq.html Starting at step 9.
I never got it to actually complete the update process, but it did format it, which solved the problem.
Oct 25, 2009 | MyMusix Audio Players & Recorders
My mp3 player cannot be reformatted
@ lady_virienn
Go to the Mymusix website and download the player update utility(located here:http://mymusix.mmvoice.com/products/audio/PD-6070/software.html )
install it, then use these instructionshttp://mymusix.mmvoice.com/products/audio/PD-6070/PD6070Vistaonlyfaq.html
Starting at step 9.
c@rl
Oct 17, 2009 | Audio Players & Recorders
Error! reformat internal media as FAT16
can you reach the data from computer (my computer)?
if so save what you think is important and then try reformatting it and then paste back the songs only.
May 25, 2009 | Audio Players & Recorders
Error! Reformat Internal Media as FAT16
Wow! FAT16! I wonder why it would want you to do that?
Here's how you do it on a Windows-based OS:
Connect mp3 player to computer
Double-click My Computer
Right-click the icon of the mp3 player
Select Format
When it gives you a choice between FAT and FAT32, choose FAT
-Tha Mp3 Doctor
Mar 01, 2009 | MyMusix PD-6070 MP3 Player
My 1gb pd-6070 mp3 says "error!reformat internal media as FAT16."
Worked for me
Apr 27, 2008 | MyMusix PD-6070 MP3 Player
My mp3 player pd6070
Worked for me
Mar 05, 2008 | MyMusix PD-6070 MP3 Player
Reformat to fat16
when u put the device in usb a screen will pop up in the high light box put in mpeg 16 then enter it the right click it to format the it should work from their let me kno if it works
Feb 29, 2008 | MyMusix PD-6070 MP3 Player
MyMusix PD-6070 MP3 Player Logo
97 people viewed this question
Top MyMusix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
