Question about Admiral AW22 Top Load Washer
Wont agitate My washing machine fills fine, but then when it's time to start washing it makes a really loud noise and doesn't agitate. It moves a little bit, but not much. It will rinse and spin fine, but not agitate? I would like to try and fix it myself but have no idea where to start looking! Thank You!!
  • 1 more comment
  • tennesseecub Nov 19, 2008
    i have the same problem its a grinding noise and sounds like some bearings or something may have went out what should i do
  • lindaward20 Nov 25, 2008
    washer fills but won't agitate. will fill, and spin. no grinding noise
  • Anonymous Dec 12, 2008
    I have the same problem, nothing seems to be broken, I suspect a sensor isn't working because that plastic thing that's grinding is in the wrong position at the wrong time.
    If i work it out i'll let you know.
My admiral washing machine fill ok, but after filling it sound like it is working however it does not aggitate. Close inspection reveal, motor is turning and drive belt is tuning as well
Posted on Dec 04, 2008
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Posted on Nov 14, 2008
  • Anna Pippin Jul 14, 2013
    Did you get this fixed??
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Hav3460aww
It sounds like the motor is heating up and tripping the overload. The squealing is probably coming from you pump. Tilt the washer back and turn the pulley for the pump by hand and if it make the squeal, replace. If it does not you may have a bad transmission.
Apr 28, 2014 | Maytag HAV3460AWW Top Load Washer
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Kenmore stopped agitating
broken motor coupling between the motor and tranny cost is about 15 bucks can get from repairclinic.com
Feb 27, 2010 | Kenmore 24032\24036 Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Admiral AW22 Top Load Washer Logo
580 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
