Big screen tv
I have a mitub, hd 1080 ws65713 and the green lite will not stop blinking i
have pushed the reset button . un pluged it and also called for tec suport.
this happed once before but the tv trun back on. can you please give me some advise
  • 934 Answers
It's probably the caps in the power supply of the DM module. That's the silver looking box on the left as you're looking into the rear of the TV... Unplug it from the signal board and remove it. Open it up and inside on the SMPS you'll find 4 1000mf/16v caps that commonly go bad... But before doing any of that press and hold the menu and input for five seconds. It will then give you a series of blinks, pause and another series. Count the blinks in each of the two-digit series and write them down. Helps to know what the Tv is showing the error code to be...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Posted on Nov 14, 2008
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
I have a 2004 WS65713 that won't start
I am not sure without seeing the tv, but I believe you have a leaking fluid picture tube. Intermittent and unusual problems usually lead me to locating drops of fluid on the chassis. The fluid is conductive and corrosive and cannot be repaired. Try taking off the speaker grill and the small access board and VERY carefully, look for spots of fluid. Look carefully near the front of the printed circuit board (nearest you).
May 28, 2010 | Televison & Video
When i plug in my tv the screen stays black and wont come on
Hi my name is Roety,
I can help you with your issue ,
Your Mittsubishi has a system the will cause the green light to blink for 70 seconds when first plugged in, if the green light never stops blinking it is either a power supply issue or a stuck keyboard button.
So do the test and reset it to see if the light stops blinking or not.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 15, 2010 | Televison & Video
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Mar 27, 2010 | Hitachi P50H401 50 in. Plasma HDTV
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Lcd
I will need the model number of your set in order to help you out with your problem. Please respond with the model number
May 09, 2008 | Televison & Video
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
