Question about Sony DVP-NS57P
We accidentally hit a button on the control that put a black box in the middle of the screen. We suspect this is a censor function, can you help us.
  • Sony Master
  • 520 Answers
This might be the text box function of the closed caption decoder. Make sure the closed captioning is off on the tv.
Posted on Nov 14, 2008
We have an NEC Plasma 60xp10 tv and NEC RU-M111 remote controller. we accidentally hit the pip button and now we can't get it to turn off. a black small box randomly pots on and off.
The black box is likely in the CC area labeled TEXT and can come from the set or a box connected for signal.
The other issue sounds like PIP or picture in picture is engaged.
Both issues may require the original remote to turn them off.
Dec 15, 2012 | NEC PlasmaSync 60XP10 60 in. TV
We accidentally hit some button on the control that made a big black square come over all our channels. We have tried everything and cannot get this off. We realize it is locked and have tried changing...
Hello
Closed Caption function is set to On in your JVC. look if there any button marked as "CC" on its remote control. If it is there, hit it till the closed caption function go off from your tv screen. If there is no such button found, get into its menu option, surf through, and get in to the closed caption option, set the close caption function OFF in that window. OK.
Apr 11, 2011 | JVC AV-32D502 32" TV
Black display box (nothing in it) in middle of screen
Someone has accidentally turned the Close Caption Text mode on. Go into your menu locate the closed caption section and just navigate to turn it off and that's it.... sometimes the remote may have it on there labeled CC.
Apr 08, 2009 | JVC Televison & Video
Mitsubishi CS 40503, black box in center of screen, takes up 90
check on the remote control for the function text maybe by mistake you put it on
Mar 14, 2009 | Mitsubishi CS-40503 TV
I have a black box that suddenly appeard in the middle of my screen. This takes up nearly hlf the screen and will not go away unless I hit the volume control or any other control. It then goes away for...
My parent's JVC did this as well. It took us a little while to solve it (and through searching for how to fix it, found this post).
Using the JVC's remote control, we pushed the C.C. (closed caption) button and cycled to the "OFF" setting. That fixed it. Using the TV's front panel setting did not fix the issue, we had to use the remote control.
Note: the "text" CC setting re-displays the black box.
Dec 16, 2008 | Televison & Video
Black box on the screen obscures view.
Nov 14, 2008 | Sony DVP-NS57P
Large black area in the middle of my screen
After doing some research I found out the the closed captioning or text box was accidentally turned on. You can try to turn off closed captioning and that might work, fortunately it worked for me!
Nov 13, 2008 | Televison & Video
Black bars on top and bottom of screen
It sounds as if you have accidentally entered widescreen mode. Explore the on screen menu to find the widescreen option & switch it back.
Jul 15, 2007 | Mitsubishi CS-35405 TV
Black Box
Hi Krautner, We have a Toshiba and experienced the same problem this morning. It is very similar to your symptoms: big black box in centre-lower part of screen. It sometimes disappears momentarily when you select a feature such a "mute" for the same amount of time the screen displays that function. Once the "mute" signal disappears, the black box comes on again. I fixed the problem by turning off the close captioning function. Somehow, it had actually got switched on. It runs fine now. I suppose you have already found a fix since you posted back in May....but hopefully this helps you or someone else putting in a similar search for this fix. Cheers Geo
May 09, 2007 | Toshiba 46HM95 46" HDTV
Sony DVP-NS57P Logo
93 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
