I have a samsung transform ultra ive only had it for 3 months . Last night it started to flash back and forth from the home screen to the vharging /mass storage screen . The battery icon shows that it is charging even though my phone is not on the charger . Does anyone know what this problem could be?
I had the same problem and eventually my phone just wouldn't charge at all. I took an old tooth brush n was cleanin the charging port with it then id blow it out n repeat and honestly after bout a half hour of doing this it is now finally charging.
SOURCE: Samsung Alias will not charge.
try with another battery. if it charge you have battery problem. if it doesnt you have motherboard problem with phone
SOURCE: my phone doesnt charge
Your phone doesn't charge? or does not hold a charge?
If the battery meter is not running when ur charger is plugged in, it could be a charging port problem or a battery problem. Go to a nearby shop to have someone try another battery & to determine if that is a battery or a phone problem. If it's the battery then buy a new one. if it's the phone, have a Samsung tech repair it for you
SOURCE: samsung flight will not power on - battery charged
The problem is a software problem.
All you have to do is to flash the phone with the appropriate software and cable.
The phone will be in good condition again.
Take care
SOURCE: the battery on my samsung
How long have you been using this phone?
I think problem is from your phone board. The board might be dusty and need some cleaning. Likewise the charging port.
Remove the battery. After that, get a phone screw driver, unscrew all the phone screws, remove the phone cover in order to gain access to the phone panel. Gently remove/detach the screen from the phone board.
Get a methylated spirit and a soft tooth brush, dip the tooth brush into the spirit and use the brush to clean the phone board. Wash/brush every part of the board with the spirit.
After that, dry the board under an electric bulb or under sunlight. Allow it to dry very well. Let the board get hot. Then leave the board for 5mins or more to cool.
Couple back the phone. Charge the battery and observe it again.
If problem persist, please let me know for further directions.
Regards.
SOURCE: samsung sgh j700 phone shows up as mass storage device
go in to settings then phone settings and go to and go down to Pc connections and you can change it to Samsung Pc studio.
i have the same problem
Samsung transform ultra unock screen black screen
