Question about Kenmore 16129 Built-in Dishwasher
Will not drain all fluid
Retains water in the bottom of the unit after it's done.
I've removed the prelimanary screen and the secondary and cleaned the third.
I poured in about 2 gallons of boiling water into the drain area, in case of grease blockage, and that did nothing but fill the bottom of the unit to the open door.
I had the same problem and changed the drain line including the air gap.
Posted on Nov 14, 2008
I have a Carrier indoor unit (cooling coils with drip pan for water) that leaks water when the unit has been running for a while. The water pump is functioning and the drain pipe has been cleared from any...
With the limited information, i would suggest pulling the service panel off where you can see what is going on. Try to determine exactly where the water is coming from.Does the drain line to the pump basin have a trap? Is there a secondary drain? Is it trapped or sealed? Is there a clean-out "T" on the primary? Is there a cap on this? If the primary drain line is not clogged, the drain pan in the unit is not clogged, and the primary drain is trapped, and the secondary drain is sealed or trapped, then i would check and see if the water is dripping directly off the coils. If it is then the coils need to be cleaned to regain the surface tension to allow the water to run down them into the condensate tray.
Hope this helps.
Sep 04, 2011 | Heating & Cooling
My softener dispenser doesn't empty most of the time, I have a front loading machine. What could be causing that? I have pulled out the tray, cleaned it, I've cleaned the inside where the water...
Unit is clogged up, see if you can take apart clean what you can see than put white vingar in dispencer let sit run unit coulpe times will clean out system and clog
Aug 23, 2011 | Kenmore Washing Machines
I need to clear the drain line on my Amana ARB1917 bottom freezer refrigerator. I've accessed the short tube that is supposed to move the water from the fridge/freezer to the drain pan ... it's...
The way to check that everything is clear pour some water over the evaperator coil in the freezer and see that the water drains very quickly. Also you could use a can of compressed air that you would use to clean the keyboadr and what not on your computer and blow it in drain and clear anything remaining
Gene
Aug 03, 2011 | Refrigerators
Does not pump enough water out, why
I would check your drain line make sure its clear and you dont have any restrictions. You could also run 4 cups of vinegar through the unit to clean your screens you may have alot of soap scum built up. Also make sure your drain is not backing up. If this is a GE dishwasher you may have a bad piston and nut assembly. The other option would be a bad drain pump. Hope this helps _MJ_
Mar 09, 2010 | GE Dishwashers
Water drips inside and freeze then thaws and runs out the door
is the frezzing occurring at the very bottom of the freezer or at the top? if its at the bottom inside only then you have a clogged defrost drain, remove the food in the unit to expose the rear panel in the inside back remove the panel chip away the ice at the bottom careful not to hit the coils, clear the pan at the bottom of ice and pour boiling water into the drain and sometimes poking a long skinny object like a piece of hanger down the tube gently only an inch or so, helps. once the water flows freely your clear, on a side note once your done clearing the drain, pull out the unit and remove the back panel at the bottom inspect the drain tube make sure it is connected, you can clean up some of the water in the drain pan, but be careful of the condensor fan. put everything back where it was and your all done :)
Sep 03, 2009 | Whirlpool Refrigerators
Dish Washer retains the water without draining....
the drain pump is fairly easy to replace. it locks into place beside the sump and motor. push tab in and rotate pump to pull out. you will lose water so have a towel handy. inspect drain hose for restrictions or kinks.
Jun 25, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
AC accumulating water, not draining properly????
For some reason, newer AC window units no longer are made with a fluid drain. I think the intent is for the unit to be mounted at a sufficient angle (it MUST be angled back so the fluid drains toward the back of the unit) that the rear (outside) fan kicks the water over the condenser coil and gets rid of it that way, it also increases cooling ability slightly in this manner by misting the condenser coil. I would suggest increasing the angle of the back tilt by adding a 2x4 maybe under the unit to allow it to tilt? Alternately, you can drill a hole in the rear corner of the unit to drain fluid, but this is not recommended for several reasons...
1) It will usually cause rust to start at the drill hole.
2) you could accidentally puncture the coil system while drilling
3) the manufacturer did not make a hole, because one was not intended.
Jun 17, 2009 | Heating & Cooling
Very thick ice collects in bottom of freezer
the drain pipe you cleaned out has a p-trap that holds water. after awhile this trap will build up sludge and possibly freeze up. i recomend defrosting the drain pan again and try some way to forcfully flush hot water thru the drain. I use a turkey baster filled with water to do this. if the drain continues to freeze you may need to install a heat trap to keep drain from freezing.
a heat trap is just a piece of 10-12 guage solid copper wire with about 3 inches in the drain and the other end wrapped around the defrost heater which is the BLACK rod attached to the bottom of the evaporator coil in the freezer compartment. if you need any further assistance just let me know Peyton
Jan 27, 2009 | Bosch Freezers
Filter
The filter panel may be replaced from the top or bottom but it's less hassle to replace from the bottom because the top tray retains a small amount of water and also because you must be mindful of working around the feed tube assembly. Also, when replacing the filter panel, clean both trays (requires removing both trays, water feed tube and drain tube) and drain tube ... use a 8 water -1 bleach diluted solution or other anti-bacterial solution and wipe the trays and pour some into the removed drain tube (not the feed tube!) and shake it up a bit. Be careful though as you do not want bleach solution getting in your eyes, nor on your skin and clothes!
Jan 21, 2009 | General Filters 1042-LH Humidifier
Kenmore 16129 Built-in Dishwasher Logo
78 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
