Question about Olevia LT42HVi 42 in. LCD Television
Unlock Olevia remote control
The Olevia remote control is locked & will not respond to certain Menu functions, ex. changing screen aspect, adjust color, tint, brightness, etc.
  • 1 more comment
  • VANCHI233 Dec 06, 2008
    THE CONTROL WILL NOT RESPOND TO CERTAIN FUNCTIONS
  • chayes440 Jan 28, 2009
    The 'solution' presented was right-on-time...a literal "home-run"!!!
  • soloman12345
    soloman12345 Aug 15, 2012
    mine wont even go into the menu it just flashes when i press menu on the tv... i picked it up at a dumb but it works good with good sound hd picture but the aspect ratio is off and the picture color needs to be tweeked. i just need to get into the menu and i dont have the remote... the dumb menu button is messed up
Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***
Posted on Jan 28, 2009
  • mjcal Jan 28, 2009
    Problem: unlock Olevia remote control
  • Linda Feb 05, 2013
    Thank you. It actually worked
I had the same problem.  This really really helped.
Thank you
Posted on Feb 12, 2009
How do we adjust color without a remote ?
Hello
If your TV has a "Menu" button on its front panel, press it once to get into its menu option. Surf thorogh and come to the picture control window. There you can see the adjustments. Will be Brightness, Contrast, Colour, Sharpness, Tint etc. Select the option you want to adjust, advance or decrese its parameter by volume Up/Down buttons. If there is no 'Menu' button on its front panel, it will be impossible to adjust these parametes withoug a remote control. OK.
Jul 24, 2011 | Televison & Video
I own an olevia lt42hvi; I need to change the picture (brightness, etc...) but it says I can only do it in "user mode." have never seen this before. I need help identifying and getting the tv...
I have a Olevia 532-b12 and it may be similar. Hit the small round menu button on the remote. A pinwheel shape should appear on the upper left part of the screen. Use the up/down and left/right direction keys to find picture, and you should be able to adjust brightness, contract, etc.
Feb 06, 2011 | Olevia LT42HVi 42 in. LCD Television
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Hi The aspect ratio on my Thomson Scenium tv (32wb842a) is out, and some shows fall off the bottom of the screen - including the tivo menu! Alas, the remote has never worked, so the manual information is...
the aspect is controlled by the on screen menu
if you can press the buttons on the side of the tv to get that screen menu then you can adjust the screen resulation
Nov 18, 2017 | Televison & Video
Is there a way to access the tint function on the Apex4088? It is not accessable when we go into the picture setup menu. It appears to be locked.
Hello
The Tint function can be accesed by the following steps.
The PICTURE menu offers options to enhance and refine the picture displayed on your TV based on ambient room light and personal preferences. Adjustment options include contrast, brightness, color, sharpness and color temperature
Press the MENU button on the remote control. Navigate using t u arrow buttons to select PICTURE. Press the down q arrow button to highlight PICTURE MODE, then press the u arrow button to select your viewing preference from 4 factory options:
STANDARD > DYNAMIC > MOVIE > PERSONAL. The STANDARD setting is recommended for most viewing environments. Depending on the ambient light level in the room, you may find one of the other options more pleasing.
To make more critical adjustments based on your own preferences in PERSONAL:
• Use down q arrow button to highlight Contrast. Navigate using the
t u arrow buttons to increase or decrease contrast intensity.
• Use down q arrow button to highlight Brightness. Navigate using the t u arrow buttons to increase or decrease overall brightness.
• Use down q arrow button to highlight Color. Navigate using the
t u arrow buttons to increase or decrease color intensity.
• Use down q arrow button to highlight Tint. Navigate using the
t u arrow buttons to adjust colors toward green or reddish tint.
• Use down q arrow button to highlight Sharpness. Navigate using the t u arrow buttons to soften or view crisper edges in the picture.
• Use down q arrow button to highlight Color Temperature. Navigate using the t u arrow buttons to select COOL (more bluish tone), NORMAL or WARM. The default setting is NORMAL. WARM mode will provide color that is calibrated to D6500° Kelvin, the standard color that broadcast stations and the Motion Picture industry consider as the most accurate to view programming.
Note: When adjustments are completed, you may select another menu by pressing the Menu button.
OK
Jan 14, 2011 | Apex Digital LD4088 LCD TV
Need to change tint, color on screen using the remote of course
Since you do not provide the make and model number of the TV so we can look for the user manual for you to read on how to make adjustment to your TV.
You just have to get to the MENU button on the remote for the ON screen setup menu and look for Picture adjustment set up to adjust the Pictures.
It should show Brightness, Contrast, Tint, Color adjustment choices.
Jan 03, 2011 | Televison & Video
Have bought a second hand philips 28pw6506, it has no remote control. Do you know how to change the aspect ratio or size of picture on screen? Have looked through the menus with the button on top of the...
Hello
To change its picture aspect ratio, you have to go to its menu. As you haven't its remote control there is an option for that, mentioned in its user manual. I hereby send it to you. Do the same and access the aspect ratio.
The television set has 4 keys which are located
on the front or the top of the set depending
on the model.
The VOLUME - + (- Vol +) keys are used to
adjust sound levels.The PROGRAM - + (- P +)
keys are used to select the required programmes.
To access the menus, simultaneously hold down
the VOL- and VOL+ keys.The PROGRAM - +
keys may then be used to select an adjustment
and the - VOL+ keys to make that adjustment.
To exit from the menus, hold down the 2 VOL-
and VOL+ keys.
Note: when the Child Lock function is activated,
these keys are unavailable
OK.
Dec 21, 2010 | Philips 28PW6506 28" TV
The picture is higher than the screen meaning that the everyone on screen no longer has a neck. How do I fix it?
adjust the ASPECT RATIO of TV using the MENU button....remote control if an original will have a button on the remote to change ASPECT RATIO on TV....ZOOM button can cause that also!
May 19, 2010 | RCA HD52W58 52" TV
Unable to change the aspect
Olevia sets tend to have a button on the remote to adjust this. try the zoom button as well. or in the picture settings in the menu
May 07, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT42HVi 42 in. LCD Television Logo
907 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
