Question about Philips Magnavox TS3260C 32" TV
Stray voltage I am getting 40 volts ac out of the F-connector at the back of the TV. Why? is there a quick fix? It is sending voltage in the cable lines. Thanks Dee
    Scholar:
  • 31 Answers
Whats a F connector please??
If you can describe it more then maybe the following may assist....
There are several types of plugs and sockets on TV receivers for many applications....A SCART type has many pins for the sound and Video outputs to various type of CD, Video, or surround sound systems, or games consoles.
There are also systems that supply a DC voltage over these various type of plugs and sockets to "drive" the input electronics at the far end of the TV receiver....A classic example is for a mast head amplifier which needs a DC voltage to make the Amplifier work and this is done over the TV areial connection so maybe this is what you are describing....More detail please...
Cheers YUBEUT...
Posted on Nov 12, 2007
SOURCE:
Only charges 9 volts
Hi Mcnabb491, in order to check out any main system electrical circuit, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
1. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
2. Check the voltage drop at the battery when you hit the starter button, anything below 9 volts you might have a faulty battery.
3. Check voltage at the battery with the bike running at 3,600 RPM should be 14.3 to 14.7 volts. If you are not getting these numbers, you might have a faulty voltage regulator.
4. Make sure voltage regulator is grounded and functioning properly, watch the video below on how to test a voltage regulator.
5. Unplug the connector to the alternator and hook your multimeter leads to the alternator (pin/socket selection does not matter) set the multimeter to AC volts, at an idle the meter should read 16 to 20 volts AC. at 2,000 RPM 32 to 40 AC volts, 3,000 RPM 48 to 60 AC volts. If you are not getting these numbers, you may have a faulty rotor, follow step 6
6. Set the multimeter to OHM'S, connect one lead to the alternator (any pin/socket) and the other to a ground, the meter should read infinity. Connect both leads to the alternator meter should read 0.1 to 0.2 OHM'S. If you are not getting these numbers, you have a bad stator.
7. Check all wiring in the charging circuit for worn or chaffed spots and all wiring connectors in the circuit for corroded, broken, or loose pins/sockets, which is the # 1 offender.
Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 15, 2015 | Motorcycles
My scooty pep is showing 10 volts in idle speed, thatd what battery is no getting charged through inbuilt charge of scotty how to resove my problem
Hi Subbu, in order to check out any main system electrical circuit, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
Nov 20, 2015 | Motorcycles
Does not charge batteryo
Hi Suzanna, in order to check out any main system electrical circuit, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Nov 18, 2015 | Motorcycles
Can a Badlands module cause a charging problem in my bike?
Hi David, in order to check out any main system electrical circuit, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
1. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with ohm meter if necessary.
3. Check voltage at the battery with the bike running at 3,600 RPM should be 14.3 to 14.7 volts. If you are not getting these numbers you might have a faulty voltage regulator.
4. Make sure voltage regulator is grounded and functioning properly, watch video below on how to test a voltage regulator.
5. Unplug the connector to the alternator and hook your multimeter leads to the alternator (pin/socket selection does not matter) set the multimeter to AC volts, at an idle the meter should read 16 to 20 volts AC. at 2,000 RPM 32 to 40 AC volts, 3,000 RPM 48 to 60 AC volts. If you are not getting these numbers you may have a faulty rotor, follow step 6
6. Set the multimeter to OHM'S, connect one lead to the alternator (any pin/socket) and the other to ground, meter should read infinity. Connect both leads to the alternator meter should read 0.1 to 0.2 OHM'S. If you are not getting these numbers you have a bad stator.
7. Check all wiring in the charging circuit for worn or chaffed spots and all wiring connectors in the circuit for corroded, broken, or loose pins/sockets, which is the # 1 offender. Good luck and have a nice day.
Sep 11, 2015 | Motorcycles
When i turn the key, the voltage meter drops to 0. no lights, no click,nothing.whats next?
Hi Rick, in order to check out any main system electrical circuit, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
Aug 11, 2015 | Motorcycles
Lincoln ac/dc 125/225 stray voltage question.We changed the aluminum transformer out for an older copper one because it was weak and the ground would bite you.
The shock can be caused by numerous issues such as high humidity, bad ground connection at the case, etc... the suppressor board is just another name for a surge protector, if it is bad, it could bleed current through the ground clamp
Oct 07, 2014 | Welding Tools
Battery down quickly after running
Hi Anonymous, in order to check out any main system electrical circuit, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
My motorcycle or scooter battery wont hold charge How to test the charging...
How to test and repair the charging system on scooter
DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Feb 17, 2014 | Bajaj CT 100 Motorcycles
I CANT START MY ENGINE
Fix Chinese 49cc Scooter that won start
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
Jan 12, 2014 | 2005 Bajaj CT 100
Voltage regulator rectifier bike ac
http://88.198.249.35/d/Pulsar-150-Workshop-Manual.pdf
Nov 15, 2013 | 2011 Bajaj Pulsar 150
Keeps blowing rectifier
Hi, Johnevens123 in order to check out any main electrical system, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary. "WARNING" never plug or unplug any electrical connector with the engine running !!!
4. Make sure voltage regulator is "GROUNDED" and functioning properly, watch the video below on how to test a voltage regulator.
5. Unplug the connector to the alternator and hook your multimeter leads to the alternator (pin/socket selection does not matter) set the multimeter to AC volts, at an idle the multimeter should read 16 to 20 volts AC. at 2,000 RPM 32 to 40 AC volts, 3,000 RPM 48 to 60 AC volts. If you are not getting these numbers, you may have a faulty rotor, follow step 6
6. Set the multimeter to OHM'S, connect one lead to the alternator (any pin/socket) and the other to a ground, the multimeter should read infinity. Connect both leads to the alternator multimeter should read 0.1 to 0.2 OHM'S. If you are not getting these numbers, you have a bad stator.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://viragohelp.com/virago-charging-systems
Fix it Friday motorcycles
Yamaha XV 535 DX Virago Service Manual
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Feb 15, 2010 | 1988 Yamaha XV 535 Virago DX
Philips Magnavox TS3260C 32" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
