Question about Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump
3 1/2 month pump burnt up today when removing water in waste mode
Also noticed a bunch of sand where the waste line dumps into the street. Have never seen this before when removing water. Coincidence with the new pump burning up at the same time?
    Problem Solver:
  • 11 Answers
Do you have a sand filter? If you do, you have bad fins in the filter. You might see it getting into the pool as well. It shouldn't be having an effect on the motor, most likely.
Posted on Feb 14, 2009
  • 547 Answers
Sand will burn out moter when you replace put a screen of fine cloth and clean 1or2 time a month
Posted on Feb 12, 2009
How does Hayward Sand filter work
Excellent answer Robco, One slight variation of an explanation about "waste"... When in this mode, water never actually enters the filter tank, it goes in the valve from the pump, and out of the valve through the waste port.
Very similar to the "recirculate" mode, it comes from the pool with the help of the pump into the filter valve, and right back out the filter valve, without ever going into the tank, and back to the pool via the return port.
Jun 29, 2014 | Hayward SAND FILTER, PRO SERIES
Hayward s200 losing suction in filter mode
Based on your question, it appears you have a Hayward S200 sand filter with 6-position side mounted valve and a standard pump with a first stage basket with a Lexan sight cover. You indicate that 5 of the six valve positions appear to work properly, drawing water out of the skimmer line, through the valve, and into the appropriate output (such as waste, recycle, backwash, etc.), but that in the normal filter mode your pump runs but no water is drawn from the skimmer through the pump basket.
What you describe is a classic blockage downstream of the pump. First, check to verify any/all downstream valves are in open position. If the filter will operate in backwash mode, it is likely not a blockage within the filter. I suggest you disassemble the 6 position valve and check for any obstruction within the valve itself. Based on your description, it's possible the obstruction might be in the bottom line going to the filter. This line narrows as it approaches the valve, and in normal filter mode an obstruction in this line could log and clog the water path, but in backwash mode water flows away from the valve toward the filter in this line, away from narrow to larger diameter. It's a long shot.
Apr 04, 2013 | Hayward Industrial Products Hayward S200...
I have 7 year old Hayward ProSeries, S-244S, H/R Sand filter. I've notice that when I vacuum the pool, dirty water returns to the pool. I've backwashed and the spider gasket is fine. No sa
sand filters only have limited filtration. If the dirt is very fine such as dead algae, it will go right through the filter. Use a clarifier to help give the filter finer filtration. Do not vacuum until you can see what you are doing, then vacuum on 'waste'
Sep 19, 2012 | Hayward SAND FILTER, PRO SERIES
I have a S-244T sand filter and I am noticing that my water level is going down about 3/4
When the pump is running is water discharging from the waste pipe outlet?
If so then the selector valve that switches the pump outlet to waste, backwash, filtering etc. is faulty.
Aug 21, 2012 | Hayward SAND FILTER, PRO SERIES
How to use backwash to waste
When the filter get clogged the pressure in the filter increases and there is less water flow returning to the pool.
If your filter is a sand filter, when you turn the valve to backwash and turn on the pump it reverses the water flow in the sand filter to flush the dirt out of the filter to waste. Look at the window openning in the waste pipe and keep the backwashing goinging until you see clear water.
Then turn off the pump and move the control valve to Rinse, turn on the pump for a few minutes, this returns the water flow back to normal but the water goes to waste to make sure the sand filter is clean.
Turn off the pump and move the control valve to filter and turn on the pump. This mode is the normal operating mode and the pressure gauge in the sand filter will show a drop in pressure.
Some pressure gauge shows a red section to indicate when backwashing should be carried out.
May 02, 2012 | Hayward Pool & Spa
If I turn to back wash, will I lose sand. Should I use waste out to clean the filter
Backwash is meant to clean the sand and remove dirt from the filter.
Waste simply pumps the pool water to the drain line and doesn't clean the sand.
If the filter has its distributors, the sand should be held in the canister.
Gary
Jun 27, 2011 | Hayward SAND FILTER, PRO SERIES
Recirculating a hayward sand filter for inground poola
no ... waste dumps the water ... recirculate recirculates but does not filter ... filter filters the water ...
Jul 15, 2010 | Hayward SAND FILTER, PRO SERIES
How do i change the sand in the filter? I am getting sand in my pool.
You will simply remove the old sand from your pool filter and follow the instructions from your users manual like you are adding sand for the first time. In case you don't have it, I am going to paraphrase it for you below.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
IMPORTANT: To prevent unnecessary strain on piping system and valving, always shut off pump before switching Filter Control Valve positions.
The correct amout of sand can be determined with this link: http://www.backyardcitypools.com/pool-filters/Filter-Sand-Requirements.htm
2. Set your controls to the backwash position.
3. Prime and start pump according to pump instructions. (be sure all suction and return lines are open), allowing the filter tank to fill with water.
4. Once water flow is steady out the waste line, run the pump
for at least 2 minutes. This initial backwashing of the filter is recommended to remove any impurities or fine sand particles in the sand media.
5. Turn pump off and set valve to RINSE position. Start pump and operate until water in sight glass is clear—about 1/2 to 1 minute. Turn pump off, set valve to FILTER position and restart pump. Your filter is now operating in the normal filter mode, filtering particles from the pool water.
6. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten connections, bolts, nuts, as required.
7. Set your filter to the "filter" position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Water is leaking out my waste line when using recirculate.
Replace the internal "wagon-wheel" looking gasket inside the valve. Its job is to keep the water going thru the valve and ports the handle is set to and not leak out of the waste port.
Aug 08, 2009 | Hayward SAND FILTER, PRO SERIES
Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump Logo
135 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
