Question about ASUS AMD 751 Chipset K7M (K7M/500/WA) Motherboard
Asus k7m motherboard connections
I have a bad power switch in a Nobilis computer with a Asus K7M motherboard. The wires accidently were pulled, the little speaker, the LCD, power and reset.
I'm trying to find a picture/diagram to show me how to plug the 'doohickeys' back onto the mb.
Thanks,
Linda
  • repair443 Nov 14, 2008
    Thank you so much. You've found me nice pictues and all, just what I needed. Have a great evening!
    Linda
    Novelist:
  • 93 Answers
The jumpers are located in the lower right hand part of the MB. Here is the user manual (in PDF format), linked from the ASUS website. It has diagrams, and instructions on connecting those wires.
http://dlsvr03.asus.com/pub/ASUS/mb/slota/k7m/k7m-104.pdf
Cheers
Posted on Nov 14, 2008
Retail drivers xp
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1537
Or is there something I'm missing by the reference - Retail?
All the drivers I pulled up are XPx86.
Means XP and 32-bit version.
What drivers do you need? Post back in a Comment.
The eMachines T2899 Desktop PC uses an FIC AU31 motherboard.
(First International Computers)
Also known as the K7M-NF18G.
This is the download link to the motherboard manual,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Click on the blue - FIC AU31 - in the left column.
Regards,
joecoolvette
Dec 16, 2012 | E-Machines T2899 PC Desktop
Cmos checksum error
This problem occurs when the BIOS battery is nearly flat. Replace the BIOS battery (most likely a coin size battery type CR2032) and then configure the BIOS - Date and Time etc.
Jul 13, 2011 | ASUS AMD 751 Chipset K7M (K7M/500/WA)...
My motherboard is no VGA driver
First, go to the microsoft Windows Compatability list and see if your motherboard (computer) and monitor are compatible with the operating system you have ... which you dont identify ... if your hardware is listed for your operating system ... look for special instructions ... follow them ...
Oh yea ... go to the device manager ... if there is anything listed there ... delete it.
Get the new drivers which should self install. If there are no special instructions ... you will go to the manufacturers web site (in the case of your computer ... www.asus.com/support) and/or your monitor manufacturer.
Thanks for your interest in FixYa.com
May 14, 2010 | ASUS AMD 751 Chipset K7M (K7M/500/WA)...
Front panel power switch & led'S pinout
asus web site download manual for a p5pe-vm thats all you need
Apr 30, 2010 | ASUS P5PE-VM Motherboard
Asus M2N / Antec SP-350
Things to try:
1. Check that the cpu fan is properly connected to the correct port marked CPU FAN.
2. Make sure the power cables are connected correctly to the motherboard.
3. Test the button switch with a multi-tester to make sure that it tests good.
4. Make sure the power switch is connected to the correct pins on the motherboard.
5. With the computer off pop the cr2032 battery out and pop it back in after a few minutes.
6. Test the power supply with either another motherboard or a power supply tester.
7. Test the motherboard with another power supply.
8. If all else fails replace the motherboard I have had a bad one from time to time even out of the box, and if you have a spare cpu you may want to test with that also. Cpu's hardly ever go bad I think I have had two go bad ever, not counting power surges and storm damage.
Sep 10, 2009 | ASUS Computers & Internet
When I push button to start computer the windows doesn't come up.
When you turn on your computer, can you hear the bios "bleep". If you don't then press the reset button and your computer should boot up normally. If this doesn't work, then your replacement switch may be faulty. If you're replacement switch is not exactly the same then you may have the wires in the wrong lugs.
Apr 26, 2017 | ASUS AMD 751 Chipset K7M (K7M/500/WA)...
Asus K8V SE Deluxe - will not turn on
it should have pins to reset it touch the two reset pins with screwe driver to activate it if still gont work you have a bios problem
Dec 05, 2008 | ASUS K8V-MX Motherboard
ASUS AMD 751 Chipset K7M (K7M/500/WA) Motherboard Logo
614 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
