Question about Siemens SpeedStream 2614 Router (ss2614)
Can not gain access to my router
I haven't accessed my router in so long however I did find the password and it will not let me in. Is there a backdoor password?
    Scholar:
  • 69 Answers
Hi bburg82319,
Sorry no backdoor password but there is a way in.
You have to reset the router, if you look on the back of the router you will see a small pin hole in it. You need to use a pen and hold that small button down for about 30 seconds.
The side effect of this is that it will return to factory settings and you will have to configure it again but there is really no other way in.
I hope this helps and please tell me how it goes. Please don't forget to rate my answer :)
Posted on Nov 14, 2008
Need password for wireless roter
If you need the login password for the router's setup page, the default username: admin, password: password.
If you need the wireless key or password, you need to access the router's setup page by typinghttp://www.routerlogin.net or 192.168.1.1 in the address field of your browser(IE or Chrome). On the login use the default username and password(admin, password).
After logging in. Look at the main menu on the left, click on Wireless Settings, from there you can check the WEP or you can setup wireless security from there if you haven't done so.
**If by chance you are unable to access the router's login or setup page, you will have to reset the router to factory settings by holding the reset button on the back of the router using a paper clip or a pen for 30 seconds while the router is plugged in to the power outlet. You will then be able to access the router's setup page using the default username and password.
Hope this helps.
Oct 16, 2011 | NetGear WNR2000 Wireless Router
How do i unlock my d link
The first thing you should do upon completing a wireless connection with a D-Link router is to set up wireless security by accessing the router settings. This protects you against computer hackers trying to gain access to your bandwidth to commit fraud against you or others. It also restricts access away from those who live around you that would rather use your bandwidth instead of paying for their own. Unauthorized users can drastically slow your network speed.
1.Enter the IP address for the D-Link router into a web browser. The default address is 192.168.0.1. This address is typically located underneath the router. Load the page to access the login details.
2.Enter the login details. Refer to your records if necessary. The user name is usually "admin." Enter in your password. A blank password is the default. Load the page to access the router settings. Note: It's important to set a password, if you haven't already done so.
3.Click on the "Set Up" hyperlink and then click on the "Wireless Settings" hyperlink.
4.Scroll down until you see "Wireless Security Mode" and select your desired level of security from the drop-down. The type of security you select depends on the electronic equipment you want to connect to your network and the level of security you want to enable. See Resources for details on the different types of security available. If you are still unsure, WEP offers a decent level of security and works with almost all Wi-Fi enabled components like mobile phones, gaming equipment and laptops.
5.Enter in your desired password into the "Password" field and then enter in the password a second time in the "Re-Enter Password" field. Select "Save Setting" to enable wireless security on your D-Link Router.
Sep 20, 2011 | D-Link DIR-300 Wireless Router
How do i change my password and username
If you have not set one up before the username and password will be in black writing on the back of the router, the usual ways to gain access to this is using a webpage Http://routerloging.net or through the ip "internet Protocol" 192.168.1.100 should say on the router which way to do it after you gain access to the router go to the security setup and follow the on-screen instructions
Jun 27, 2011 | SMC : Cable/DSL Broadband Router...
I can`t access router setting. I haven changed user name an pass. I tried to shut down the router an wait for an minute. Then I turn it on an tried to access 192.168.0.1 . After than in the username field...
If you cant remember the username and password of your router you can reset it to bring back the default settings of your router to be able to access it. At the back of the router you need to press and hold the small hole using a pen or a paper clip for 10-15 seconds. after that the router will return to its original state. Keep in mind that it will remove all the settings that you've saved. Then access the router using 192.168.0.1 and using its default username and password
Thanks for using Fixya
Jan 27, 2011 | Levelone CP TECH WBR6002 Wireless Router ...
I JUST MOVED AND NEED HELP HOW TO RESET MY NETGEAR WGR614V9 WIRELESS ROUTER. WHAT DO I DO TO RESET MY PASSWORD TOO I THINK. thank you
Turn the router over and check the defaults on the bottom of the router. try the default admin and password to see if you can gain access to the router. Most people use the defaults so this might be a good way of gaining access. Otherwise there is usually a reset switch on the back or front of the router. You wil need a paper-clip[ to reset the switch. then you can use the defaults to gain access and reconfigure the router.
Jan 14, 2011 | NetGear WGR614 Wireless Router
I changed my password but I forgot it
Do you have a Linksys router and you have forgotten your password or you want to reset the password to the default. Firstly you must have physical access to the router. This article is basically for WRT54g and model BEFW11S4
If you have changed the password from the default password and have forgotten the default or your router did not come with any documentation.
To regain access to the router try the following. In the username field leaveit blank and in the password field type admin
Username / leave blank
password / admin
The Rest Button on a Linksys Router
To reset the router
While the back of your router might look different, the reset button is usually clearly marked. To reset the router to the default password, insert something thin--like a pencil point--and depress the red button. Hold that for a few seconds. The password for your Linksys router should have reverted to its default.
Try accessing it from a machine that is plugged directly into it. The default address is usually http://192.168.1.1. When you gain access to the router then you can change the password to any word of your choice.
May 28, 2010 | Linksys Wireless-G WRT54G Router
I forgot the password, how do i gain access to my closed router
you need to hard reset the router to factory.
small reset hole at the back. This will put the default login back on. This is the only way, careful if you do this more than like you will also wipe out your broadband settings.. which will need to be reconfigured to reconnect online
Apr 15, 2010 | Airlink AR430W Wireless Router
Cant remember my password to gain access to my router to gain internet.
Should be a tiny button on back, you might need a pencil to press it, just press and hold for about 10 seconds to reset to factory settings
May 27, 2009 | Linksys Wireless-G WRT54G Router
Siemens SpeedStream 2614 Router (ss2614) Logo
416 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
