How to clean coffee spill from Toshiba laptop
Laptop: Toshiba Satellite L300D
Model: Satellite PSLC8A-02200Y
Issue: I have managed to spill some coffee on the keyboard of abovelaptop. Spills are not covered by warranty so Toshiba won't repair it. Due to spill, some keys have become stuck so when it starts up, it makes a beeping noise. The only issue caused by the spill is sticky keys so I need to clean the keyboard. The laptop was left to dry for two weeks already.
I need step by step direction on how to open the laptop (with pictures and details) and then how to clean the coffee. Please send details about this model only - I have looked at internet and there are many related model but their directions don't work with this particular model.
Please send a detailed solution and not just one two advice.
  • 1 more comment
  • shanepo Nov 14, 2008
    Please read the question before you respond. This will save my time as well as yours. I am looking for a detailed solution NOT general advice.
    Can you direct me to a tutorial. I can't find any latches.
    I have manage to take out the keyboard. Can anyone tell me how to clean it? which liquid to clean with?
    Sergeant:
  • 207 Answers
Shane,
You can use a qtip with rubbing alcohol to clean up the spilled coffee.
Dip the qtip in the alcohol and squeeze out any Excess. Use the qtip to clean up the mess. Then use the dry end to dry the cleaned spot as much as possible. You may need many Qtips depending on how much of a mess you have. Once you have the Laptop cleaned leave it apart for about 10 - 15 minutes to allow any residual alchohol to evaporate. You should now be able to reasseble your laptop and give it a try.
Hope this helps you.
Dave
Posted on Nov 14, 2008
    President:
  • 2,712 Answers
The best would be to use isopropyl alcohol (rubbing alcohol, cheap and easily available). It cleans well, and dries almost instantly..Since you got the keyboard open, this would be the way to go..
You could also try the wet-wipes, same formula, but with a deodrant as well :)
    Genius:
  • 1,550 Answers
Here is the link with pictures to help you to help you opening your laptop
Laptop repair
Use dry clothes to clean the parts and be careful while you clean inside.
  • SAM ANDERSON Nov 14, 2008
    Dont use liquid at all use dry cloths to clean it properly .
  • 728 Answers
If you do it this way, you should not have to open it. All I need from you is to answer one question: When you say the keys are sticking, do you mean that the key is stuck in a pressed position or the key can stilled pop up and be pressed down? `If it is stuck in a pressed position, then you just need to get something thin and flexible like a credit card to get into the crack between the keys. To pull up the stuck one, insert the flexible object into the crack and slightly wiggle it until the key pops up. Do that with all of them. Then get a can of keyboard dust remover with a straw and aim it in the cracks that were beside the stuck keys. Spray it in each area for about six seconds and try pressing the key to see if it sticks anymore. The condensation that comes from the spray should free it up making it stick no more. This should work.
  • Jazz Boyce
    Jazz Boyce Nov 14, 2008
    You can use this website to see how to clean keyboard in short: http://www.youtube.com/watch?v=jxHEqyhWl...
    If you do not see it in the video, you will need compressed air, cotton swabs, and water. You can wash the buttons off in the water and dip the cotton swabs in the water. Use those to clean the area under where the keys go and in the key button sensor to get the dried coffee up. Then put the keys back and test it. It should work.
  • 6,487 Answers
You might wanna check this link for some steps that you can try in cleaning you keyboard
http://techipedia.wordpress.com/2008/09/05/how-to-clean-your-keyboard-part-2/?referer=sphere_related_content/
  • 73 Answers
Hi there
This is the best article I know for this problem
http://tech.yahoo.com/gd/saving-your-laptop-after-a-spill/153194
It comes with instructions step by step
    Scholar:
  • 69 Answers
Hi shane,
you are very lucky that nothing was damaged. there is an easy way for you to clean you keyboard from the "sticky stuff". there is a quick drying foam that is ironically called foam cleaner that you can get at at this link. Its cheap like 6 bucks and comes with some goodies. It is very easy to use.
This will lift any junk of the keys and has the added benefit of being anti-bacterial as well.
One can would last a normal user for a long time and it does come in handy.
It will unstick the keys and make them as clean as they were when you bought your machine.
I hope this helps, and please dont forget to rate.
  • 1 more comment
  • Stellyx
    Stellyx Nov 14, 2008
    sorry i forgot to post the link on how to open your keyboard its something my buddy and i put together a video to help you out here
    This is not your model but the concept is the same.
    Disclaimer: careful bad things can happen, not responsible etc etc :)
    good luck and tell me how it goes, please don't forget to rate.
  • Stellyx
    the best solution to this problem is to install the software directly from the mymusix site. then when prompted connect the drive.
    I noticed that alot of people have this problem and the answer was to get the software at mymusix.com and reintall
  • Stellyx
    last comment meant for another post.
  • 13,433 Answers
Heres a brother model, instructions with pictures
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
Note that there are 3 pages on the guide the links are on the bottom, it should be helpful.
Is there anything special about the beeps? short? long? computers report hardware errors with beeps if you could count the beeps short and long and then use the add a comment button so I can respond to you, if you repost the problem you will most likely get another expert offering some other advice.
Thanks, Ekse
  • 113 Answers
This solution might sound funny u can try and it will work , cover the keys with the dry rice and leave it for few hours , as rice have tendency to absorve water, leave it for a hour and it will absorb the water,
2nd i wd suggest not to dismandle the product at it will damage more, remove the battries and take a hair dryer and set it low and blow from distance as direct heat will damage the circuit, and blow for some time.
or try  vaccum cleaner
  • parthasarathy Thandapani
    u  can use shaving lotion as it has got alcohol, then u can allow it to dry
    Genius:
  • 1,847 Answers
Switch of the laptop till it is dry.
  • Legin Varghese
    Legin Varghese Nov 14, 2008
    do not switch on the laptop until the coffee is dried completely,you can also you a hair drier , once dry take of the battery and clean with alcohol and clean cloth.
    If you want can also clean the keys by removing it, the laches to remove the keyborad will be above the Function keys.
  • Legin Varghese
    You can use slight wet cloth and make sure it is dry completely before rebooting.
    Thanks
    Kevin
  • 19,396 Answers
Do not start the laptop
Try first cleaning the keaboard with wet cleaning tissues, you can by the ones for computers at any computer shop or use the ones for skin care, providing that no liquid gous inside the circuits.
If coffee spilled inside and you already tried starting and did not start, then you can remove the keyboard. being very careful not to damage the ribbon cable, and leave the laptop to dry.
If you want to clean the boards you use circuit cleaning solution, that you can buy at Circuitcity.
If you have not done a similar job before , it is better calling a technician.
Click the links below to get detailed disassembly instructions.
A few things to know before you start taking your laptop apart
Then Click right here.
    Sergeant:
    Champion:
  • 283 Answers
Have you tried to open a laptop? If not, try to go to service center it might causes more damage.But if you can, use a tissue and a ligther fluid to clean the keyboard membrane. Dry it well so that it cant causes shorted.... Thank you for using fixya....please dont rate me if you are not satisfied with my suggestions.
Model number location for a toshiba laptop
In backside the laptop you can see the barcode details where in the model number is available. Please check the stickers in the backside of the laptop where they will mention the model number.
Thanks
Apr 02, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
Fix errors
Run a complete virus scan (I recommend Norton) and then download and run Malwarebytes. I you need a free anti-virus try Microsoft Security Essentials here: http://windows.microsoft.com/en-US/windows/products/security-essentials
If the problem persists post back
Dec 18, 2011 | Toshiba Computers & Internet
My Toshiba L300D laptop needs resetting to factory settings.. how do i do this?
if yr laptop still can logon, recover yr system use system recovery on yr laptop, if not use cd recovery or recovery partition on yr laptop hard disk
Feb 19, 2011 | Toshiba Satellite L300D-ST3501 Notebook
Toshiba Laptop Satellite L300D. FN key not working. How do I solve the problem?
Usually the easy fix for this is to swap out the laptop keyboard. They are inexpensive, usually $20 or less, and are not to bad to swap out.
Sep 21, 2010 | Toshiba Satellite L300D-ST3501 Notebook
How do i replaced the charger socket in my l300d toshiba laptop
I have come across this issue in a number of Toshiba laptops recently. The DC jack assembly (which includes a wiring harness and the DC jack) actually breaks away from the bottom laptop housing. What I have done is to glue the jack back in place using a hot glue gun. You need to be careful and observe how the right speaker (located on the top housing) is situated. Be liberal on the glue and make sure the jack is encased in the glue. I have not had any units returned after this was done.
Good luck
May 15, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Bluetooth activation on laptop
Check device manager to be sure there really is a bluetooth card in the laptop. Also, look for a button on the laptop to turn on BT. Let me know if this helps or not.
Aug 08, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Touch pad
You probably fried something with the coffee.  There are replacement touchpads available if you know how to replace them if not an authorized dealer will be able to point you in the right direction.
Jun 02, 2009 | Toshiba Satellite Laptop with AMD Athlon...
After cleaning for coffee spill dried up coffee spill my computer start well but i have touch pad unresponsive
You may want to open the laptop and check for damage to the touch pad including connection to the mother board. If you can not see any visible damage to pad or connection replace with another pad. Good Luck
Jun 02, 2009 | Toshiba Satellite L355D-S7815 Notebook
Type of wireless
http://explore.toshiba.com/laptops/satellite-pro/L300
this shows all the l300d models at the bottom and what the card is in it. I would get the newest available for speed, and reliability. it is N. an N router will be backward compatible with B, G, and A
Dec 22, 2008 | Computers & Internet
Computers & Internet Logo
3,443 people viewed this question
David Payne
David Payne
