Question about Lexmark Office Equipment & Supplies
I keep having paper jams and nothing is working to fix it.
  • Anonymous Jan 31, 2009
    There is a paper jam and I don't know how to fix it on a Lexmark E250d printer.
    Genius:
  • 1,913 Answers
Open the door then put away cartridge then check there is not any papaer jam also check in back side for paer jam.
Posted on Nov 14, 2008
How to fix CM2320 MFP PAPER JAM
if you don't find nothing inside printer and you are SURE there is no paper inside machine try to clean or replace pickup roller, if you wanna be sure about that try to print from Try1, if it work the problem is in try 2
Aug 28, 2014 | HP Laserjet CM2320nf All-In-One Color...
CLP-320N KEEPS TELLING ME TO CLOSE DOOR...ALL THE DOORS ARE CLOSED
Most likely you should check the 'door open switch', probably its broken.
Apr 24, 2014 | Samsung CLP-315W Laser Color Printer
Canon PC735 copier, paper jam light keeps coming on but there isnt any paper or anything blocking the machine. Tried resetting but nothing has worked. What can I do?
My canon copier pc735 says we have a paper jam- but it does not. We just replaced the cartridge and it wont work. I had them send me a new cartridge, but its the same thing- paper jam. Help!
Oct 10, 2009 | Office Equipment & Supplies
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Constant paper jams
OPEN UR PRINTER N CLEAN IT USE AN ATISTATIC VACCUM OR CANNED COMPRESSED AIR . ITS HAVING THE PROBLEM THERE SHOULD BE DUST OR DEBRIS IN PRINTER . INSPECT FOR ANY BROKEN PARTS IN THE PAPER PATH . IF U FIND ANY TO INVESTIGATE OR REPLACING THE PRINTER.THANKS
Apr 23, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Paper jam message on HP C4599 when there is no jam
I had the same problem. I called HP and went through the steps they had asked me to go through to fix it. It took about an hour. Nothing worked. They offered me a replacement. I said no, and they offered me a $150 gift card for Staples.
Apr 10, 2009 | HP Photosmart C4580 All-in-One InkJet...
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
CANON PC735 COPIER, PAPER JAM LIGHT KEEPS COMING ON BUT THERE ISNT ANY PAPER OR ANYTHING BLOCKING THE MACHINE, TRIED RESETTING IT NOTHING WORKS PLEASE HELP.
For the problem with the personal copier pc735 paper jam, I had the same problem. I was told the problem might be fixed by downloading the drivers and reload them. The PC735 I have does not have drivers nor a scan. My problem was a spring fell off on the idler gear and had to be reattached. I then cleaned the interior and this fixed the copier. You might look to see if a spring came loose on the back side of the bottom frame. I'm no machanic so I had a canon rep fix it for me. This fixed my problem. No more paper jam light.
Bob At DottyW4658@aol.com
Jul 16, 2008 | Office Equipment & Supplies
Jamming
Hi Scott, My experience is if there was a jam and it still says it's jammed after clearing the paper you missed some. Even if the sheet that caused the last jam didn't tear it may have moved a torn piece of paper that was in there from before. Check again, really well for small pieces of paper stuck somewhere. Hope that helps. If not let me know and I'll see what else we can do. El Duderino
Nov 16, 2006 | Canon PIXMA MP150 All-In-One InkJet...
116 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
