Question about All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater
Starts, fires but won't keep lit.
I have a All Pro SPC K100 that worked great and then tonight, started and lit about half way but then went out and smoked!! I just purchased this used and have tired it few times no problem. I have took the filter out and washed it and will let it dry. I put new fuel in hopeing that helps. I have no book to guide me for trouble shooting. It will run but no heat and then will shut off. I have no idea where to stary. I notice when i took the filter panel off, that it had a couple knobs and a air port stating so much psi but i have no clue what that is all about. Any help would be great.
Thanks
ken
  • RAJMICKEY Dec 24, 2008
    I have the same SPC-K100 and same problem worked great then started to sputter and not stay fired fan runs but no heat any solutions pls let me know MRJ_92599@YAHOO.COM
SOURCE: Fan turns on starts blowing and a lot of smoke.
when you start it the smoke starts wright away it is not getting the right air flow takethe top part off and started see what it does if it stays running try to ajst. the fens ok .
Posted on Dec 30, 2008
TheMobilian
  • 8220 Answers
SOURCE: I have an All Pro SPC K100. The fan runs and mist
You probably have a klixon/high limit popped out or failed. This video shows were it is on another heater and although yours is different they all have limit switchs thanks to ralph nader. LOL
Check this out: HERE
Posted on Jan 09, 2010
mxc2
  • 146 Answers
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If the units starts up and runs good and slowly goes out it will normally be due to a lack of fuel getting to the nozzle. When there is not enough fuel being delivered to the nozzle from either a clogged fuel filter of dirty air pump output filter the unit will slowly shut down from lack of fuel.
If the unit shuts down while it is running properly and the nose come is orange then you probably have a problem with a photocell or the flame out control.
If you have other questions you can contact our service department at 269-685-4125 at extension 224
Thanks
M Cramer
www.allpartsinc.com
Posted on Jan 05, 2011
heatman101
  • 43501 Answers
SOURCE: all pro 170T dual fuel heater starts and runs for
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 16, 2011
  • 13 Answers
SOURCE: Heater will not get fuel. It is "All Pro" Model
First check the filters such as fuel,intake and esspecially the air exhaust filter. If the exhaust filter is dirty it will restrict air flow preventing fuel delivery. You may also want to check the hoses. If they are cracked or don't fit tight it could cause an air leak which would prevent fuel delivery. Also when you check the fuel filter check to see that the fuel pickup tube is still connected. After all of this if you still have not found the problem and fixed it you will need to check the pump pressure. Check the operators manual for pump pressure specs. if they are not written on the heater side panel.
Posted on Jan 22, 2011
All pro spc-k100 will not fire. just bought the unit used not sure if the ignitor adjustment is correct. if i take the ignitor and short it like a spark plug against the frame it works fine. putting it in...
try lighting with match or flame instead of lighter, assuming you can get to pilot or flame from outside the unit. if still no flame trouble is in valve (s) or no fuel.
Feb 28, 2012 | Grilling
I have a spc-40 heater i can not get it to stay fired up i press the fuel button and it does lite but after 15 to 20 i release button and it goes out what do i need to do to make it work again
Ensure all your connections are tight and not leaking. I would shot off the tank using the valve on the top. Disconnect it, then re-connect it. Once connected, ensure the fan on the unit starts to turn. Then you can slowly open the valve, give it a good 4-5 turns to ensure it is open. They try the ignition sequence again.
Feb 28, 2011 | All-Pro Propane Garage Shop Heaters - All...
I have a toro wheel horse classic 312-hydro. Sometimes when you turn the key nothing. It always ends up starting though. It might take a while but it aways starts. When is does turn over it starts just...
just purchased 1995 says seller, serial # says 1990, 312h kohler wheelhorse 157 hours, royaly maintained, new condition runs great when it starts,turns over great, spins fires spins fires over and over then back fires thru carb, flames this no start, help going to snow tonight
Aug 23, 2010 | Toro Garden
SPC-40 wont stay lit
Problem is either the thermocouple or the thermoelectric valve. I have one of these as well with the same problem. On mine it is not the thermocouple. I have replaced the thermocoupler and still have the problem. A thermoelectric valve is $42.25 at http://www.masterheaters.com/propane/
Im looking for a cheaper part. Any suggestions?
Gru es 1234 @yah oo.c om
Jan 12, 2010 | All-Pro Propane Garage Shop Heaters - All...
No heat
It is either the igniter or the limit. Their is a limit mounted
at the 12 o'clock position beside the igniter. If you look at this video you will see it. Well the base of it and 2 philliphead screws that hold it anyway. LOL
Check ot the video HERE
Jan 08, 2010 | All-Pro Propane Garage Shop Heaters - All...
I have an All Pro SPC K100. The fan runs and mist comes out the heater, but no flame or heat. Rich
Jan 08, 2010 | All-Pro K175 Heater
SPC-12 SPACE HEATER WON'T STAY LIT?
When holding button in,you are overiding themocouple funtion. You probably need to replace the thermocouple
Feb 27, 2009 | All-Pro Propane Garage Shop Heaters - All...
Flame goes out
the most common problem is the flame sensor located just behind the fire chamber, about two inches long in a round rubber boot with two wires. you can get one from mr. heater for about 3 bucks. the wires are a different color but all you have to do is splice them to your old wires. it doesn't matter how you connect them.
Feb 02, 2009 | Reddy Heater-30-55,000 BTU Variable
I currently have a Scheu Universal 250, 250-A all pro spc-250, SPC 250-A 250,000 BTU constructtion heater that I can't get working. I've connected to a propane tank w/ regulator and can't get it to fire. I...
I have had the same problem on a smaller unit (30,000 BTU). I remove the cover, take the thermocouple out of the burner area, and clean it until bright with either scotch brite or very fine emery cloth. The deposit on the outside prevents it from tranfering the heat to the hot end of the thermocouple and in turn to the sensor. I usuall do this once a year. The cleaning hasn't worked for me recently but the unit is 12 years old now and I will look for something else to fix.
Dec 23, 2008 | Heating & Cooling
All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater Logo
77 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
