Question about Sony Playstation 3 (PS3) Console
No audio video
I unpluged the unit now i have no audio video i need help thanks
    Problem Solver:
  • 37 Answers
PS3 is The amazing device by sony but it has some common problems like sound , video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Feb 27, 2009
No sound from bose 321
You need to localize. Play a DVD, does the same audio cutout happen? Do you have the center dvd or the left mounted dvd? The console unit has input jacks for external audio inputs, put an external audio source in and see if the same cutout occurs. See if the external output jacks lose audio or just the system speakers, including subwoofer. This may help localize which unit has the problem.
Is the console stacked above or below other electronic units, it may be a heat related cutout? Reseat all your interconnect cords, I have seen corrosion occur on the square connectors.
These are expensive to have repaired, good luck. If you're daring enough, you make find free service manuals on websites like Elektrotanya, hifimanuals, hifiengine, and eserviceinfo (.com)
Jul 15, 2016 | Bose Av3-2-1 Series Ii Media Center...
Is there a way to reset the Onkyo quartz synthesized tuner amplifier R1?
Hi Madaline, all you need to do is to unplug the unit from the AC outlet for a least an hour and the unit should reset, Thanks, JT
Nov 09, 2015 | Onkyo Audio Players & Recorders
Unit won't change from tuner
If you have not done so,try unplugging the unit for a short time,at least 5 min. then plug in and try it again. the microcomputer my be "locked up" due perhaps a static discharge this may solve the problem.If this doesn't fix it you need a good electronic techs help.Good Luck
Mar 04, 2014 | Technics Audio Players & Recorders
Hmdi input has lost audio
several things could cause that:
1. hdmi cable is no good.
2. receiver and TV are not fully compatible. I noticed few times that philips tvs had problems with denon receivers. Some times you need o unplug hdmi cable and plug it in back to get sound.
3. firmware issue. depends on model of your receiver there could be a software upgrade to resolve the problem.
4. somebody (kids) accidentally pressed some buttons and reassigned video input for that video source (video select button on a remote control), etc. Resetting the receiver usually helps.
5 Receiver (hdmi board is no good) or TV is no good.
so next time when it happens check video source, video input assign then try to swap hdmi cable and TV
Nov 28, 2011 | Denon Audio Players & Recorders
I am not able to turn off the alarm on my akai IM 861 ipod doc music centre
So, if you unplug this unit from the wall completely, let it sit for a good 2 minutes, and replug it in, is the alarm still going off? If so something has definitely malfunctioned inside the device. Let me know and I can continue to help!
Thanks
Tim
Sep 16, 2010 | Audio Players & Recorders
How do i reset dennon avr 1000
turn it off and unplug from outlet, wait 1min
then press audio and video buttons together on right hand side of unit
hold these and turn plug it back in to outlet
wait until display flashes every second then release buttons
turn on unit to reset
note all settings will be factory default.
Hope this helps
Thanks for using FixYa
Jun 12, 2010 | Denon AVR-1200 Receiver
I have an onkyo tx-sv444 receiver that the word protect comes across the screen and then shuts off what should i do about it
When the word protect shows up it means trouble. The circuit that shows the warning and shuts the unit from working has detected a short somewhere in the unit. More than likely one of the output transistors but not always. Have you had a power failure lately? Lightning strike? Power bump? If so the problem could be in the Low Voltage power supply. First unplug the unit. Take the bottom off if it has a panel which can be removed separate from the complete bottom. Under the panel should be the output transistors. Check to see if any are shorted with a DMM. If you find any they will need to be replaced. If you do not find any you will probably need a competent tech to troubleshoot the unit. Let me know if you need anymore help.
hardrocko
Feb 18, 2010 | Cambridge Audio Azur 540R Receiver
Programing Mode Backward
happy to help, just ask me here:)
regards
Graeme
Dec 04, 2007 | Onkyo TX-SR601 Receiver
My unit has power, but it won't turn on at all.
This means that something is seriously wrong with the unit(blown amp, shorts, opens, etc.) however, you can reset the unit by unplugging the unit, holding the A and B channel buttons on the face of the unit and plugging in the reciever. the display should flash at 1 second intervals. if it doesn't stop flashing on its own then unplug and replug and you should be good to go! good luck.
Jul 31, 2007 | Denon AVR-2800 Receiver
Sony Playstation 3 (PS3) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
