My TV won't come back on.
When I went outside and came back in after about 10min my TV was off i tried to turn it back on and the power light came on green heard the sound then the power light flashed red a couple of times then shut off, it does the same thing every time i try and cut it on. please help me!
    Champion:
  • 225 Answers
If your TV is a few years old, most likely a large power capacitor has shorted out. A tech will have to trace the problem for you, sorry.
Posted on Nov 14, 2008
    Scholar:
  • 181 Answers
The fuse on the main board is blown.replace that fuse.
I have a VIZIO VF550M LCD T.V. I was watching T.V. and it went off and won't turn back on. What can I do to fix it?
Outside of leaving it unplugged for 30 minutes to do a reset, there's not much you can do. It sounds as thought the set needs repair. Sounds like you have an issue with either the power supply or main board
Apr 19, 2013 | Vizio VF550M 55 in. LCD HDTV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I have a 42" Samsung
This clacking and clicking noise could have been coming from a capacitor going bad in the tv. If this is the case where the tv will not turn back on, I would suggest calling samsung to try to get a replacement or get the tv serviced. Trying to replace bad capacitors can be a tedious job and requires knowledge of soldering small components. This may also void your warranty if you still have coverage.
Aug 19, 2011 | Samsung PN42A400 42 in. Plasma TV
TV was working fine till Friday 29 Jan 11. Went to turn it on screen was dark blue,but sound was on, after about 10min the screen went to bright blue then the picture came on. Saturday the same thing,...
The problem you are having is the power supply in the TV is failing. When you try to power the unit on you get on power or a slow turn on. It also can explain the problem of not running at full 1080p resolution because the higher the resolution the no power is required to operate the TV. Check out the article that explains the problem and how to repair it.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
I hope this helps, if so please rate our solution.
BuddyMc
Jan 30, 2011 | Element Electronics FLX3711B 37 in. LCD TV
Grand am wont start. it is turning over tho. i tried the security fix (leaving it on for 10-20 mins, then off and trying) but it still won't start.
Hello: Try this, Turn key on, try to start, let k/switch come back to run, let set for 10min(security light out) turn key off 10sec, turnkey back on let set 10min, turn key off 10 sec, turn key on let set 10min. turn key off 10sec. turn key on start car if it doesn't start and the security light is flashing you have a passlock problem and it will require a new lock cylinder assembly and the above learn procedure.
Jan 27, 2011 | 2001 Pontiac Grand Am SE
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
No power
When I turn on the tv, there's the green light, that shows it's on, but it's blinking green and the screen is black
Jul 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
My 50" hitachi ultravision won't turn on
i got a 62VS69A model type hitachi tv.... and it was thunderin and lightning outside all day .... and i left it on ... and when i woke up ... it was off..... and when i went to turn it back on.... it blinks blue,, then the light below it blinks red.... and the light below that light blinks red .... and then the first blue one again ... and over and over again ... untill finally it juss stays red... i donno whats goin on with this tv... im assumin it was the bad weather outside that did it but im not sure..... can someone PLEASE help a brother out ? lol
Nov 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
