Question about Microsoft Xbox 360 Console
Cannot connect to Gateway
I had connected previously, but had to disconnect. Trying again, I cannot connect. The wireless connection settings on the xbox 360 is greyed out so I can't put any information in there. I have an ethernet cable going from my xbox 360 to my gateway. There is no green light that lights up on the back of the gateway after plugging in the cable from the xbox 360. But if i plug the cable into my computer , it does light up green. Anyone know what that means? Thank you.
  • 903 Answers
Lots of people seem to be having problems with wireless adapters, I don't know about ethernet cables, but I have done some searching for you and if you click on the link below and scroll 2/3's down the page, there is a screen shot of how you can connect your 360 to the net from your computer. (it's not a fix to your direct problem, but it is a short term fix)
http://www.techsupportforum.com/gaming-forum/console-gaming-support/193635-360-wireless-adapter-trouble.html
I hope this helps
Posted on Nov 14, 2008
I have a lynksys router. It will work with our mac, but if i try to get online with my pc, neiter will connect or if one is connected, it will disconnect. can i fix this
I see that you are having issues with your network connection, I believe that you are trying to connect wireless on both systems.
* Check your Linksys for settings that limit the routers wireless connection, most wireless routers have an option on how many computers can connect wireless to the router, a wireless signal does not chose what OS to allow for a wireless connection.
* get in your Linksys Routers Setting page from IE or Firefox using your Default gateway IP from there on you can check your Routers settings, user name depends if your internet service provider changed the Routers user name and password but for a Linksys try admin / password or admin / admin for the User name and Password field.
Hope this helps you thanks and have a good day.
Mar 30, 2011 | Cisco Lynksys Dual Band Wireless N Gigabit...
Samsung BD 6300 blue ray player does not connect to wireless access point. Gateway ping seems to be the issue, current gateway is on the network. Using my landlords router with his permission. Suggestions...
I'm not sure if I'm reading this right but, Is the Access Point in your apt? Or are you trying to access his router directly with your 'Player?
If you are trying to connect to an actual Access Point, try connecting to the AP from your computer either wireless or via the Ethernet cable and set it up to access his router/internet. When you can surf the Web or access his network on the computer using the AP then unplug the cable if you used it and just go into the Samsung's network settings and try again.
The only other thing I can think of is make sure his router is set to MIX, b/g/n speeds.
Jan 04, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
My wireless is going on and off, what's the problem?
Frequent wireless disconnection can be caused by different factors such as:
• Wireless interference within the network
• Wireless settings of the Linksys ADSL gateway are still set to default
• Firmware is corrupted
NOTE: Before going through the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
To resolve intermittent wireless connection, you need to perform the following steps:
i. Reducing Wireless Interference
ii. Customizing Wireless Settings of the ADSL Gateway
Nov 11, 2010 | Linksys Wireless-G WRT54G Router
Trying to connect to x box live. just bought the
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :) Tell your friends and ratings are nice. Just kidding, I just hope I helped.
Jan 18, 2010 | Microsoft Wireless Network Adapter Xbox...
Get ''pending'' for ever when trying to connect to wireless AP. Log says can't set wireless frequency - operation not supported and then DHCPDISCOVER never gets an answer. If I use static IP simply get...
I had a similar problem. Hit "Fn"+"F2" to cycle the wireless off then on again. Allow about 30-60 seconds to get IP and DNS info from the access point.
Then, using the network adaptor icon in the utility bar (on the bottom right), right click, select "all network connections". Click each network adaptor and from the "Connection Tab" Disconnect each adaptor. Then restart the wireless adaptor with the "Connect" from the "Connection Tab".
I'm assuming that there are no funny settings in the Properties which are preconfiguring the adaptor for a previous connection. If so remove any present values. Leave the connection set as DHCP as this is teh most common way that adaptors will get their settings from teh access point your attempting to connect to. Cheers.
Jul 10, 2009 | ASUS Eee PC 701SD
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
D-link di514
Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add 192.168.0.10, Subnet Mask255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Aug 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
Not letting me on the ip address to set up
You may be able to verify the router's address by checking the Default Gateway setting on your computer. For example, at the Windows command prompt, type "ipconfig" to display your current ip address settings...including the gateway (router) address.
Jan 11, 2008 | Actiontec GT704WG Wireless Router...
Microsoft Xbox 360 Console Logo
56 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
