Question about RCA F25254GY 25" TV
RCA F25254GY I cannot replace the old cable settings from my cousins house to the cable in my house 30 miles away. I have gone through the setup and autoprogram and it is still on the same old channels!! Is there any way to erase the old ones so the new ones can be registered? PLEASE HELP ME!:(
ITS FR0M 1998 BY THE WAY
Posted on Sep 12, 2007
SOURCE:
Why is my color on the TV to be blue and green?
Definitivel you hav a serions problem with red. I dn't know how it works but you shoudl take ti ti rapreasr
May 18, 2015 | RCA F25254GY 25" TV
Rca digital flat antenna
First you have to be within range of an HD tower. Second the antenna will have to be on the side of the house that the tower is on. This is true even with an Omni directional for best results. Smaller antennas are only good for an unobstructed distance of 30 miles, that bigger ones will get you 80 to 100 miles. If the cable run from the antenna to your tv is over 50 feet you will need to pre amplify. If you have further runs in your house from the TV you may also need an amplifier on that side as well.
Apr 06, 2014 | Televison & Video
Old tv buttons got wet
The tv buttons are actually small "tact" switches which are contaminated with the vinegar and shorting themselves. Unfortunately replacing these is your only option. You may get lucky to just turn if off and let air dry for a few days.
Mar 13, 2014 | RCA F25254GY 25" TV
Tv will not change channels past channel 2
Hello
Check if any microswitches on its front panel ahs been strucked. Replace all the microswitches at the same time. it won't cost more.
Mar 03, 2012 | RCA Televison & Video
I recently bought an Xbox 360 and plugged it into the back of my TV. However, the TV refuses to show anything from the Xbox 360. I tried Autoprogramming it, and it erased all of my channels except for 1,...
MOST of their older sets are set up where the AV inputs are channels 90-93 ; if you had no signal other than the game the set will skip all those channels out.
If you have a working remote for it direct enter 90-93 one at a time .
Nothing hooked to cable fitting means set will see no signal and skip them out when auto program is engaged.
SD TECH
Sep 23, 2011 | RCA F25254GY 25" TV
My dvd player was unhooked from my tv during a move. i no longer have the dvd manual. apparently I am connecting something incorrectly, because I have audio but no video. can you help with a verbal or...
The DVD player and Tv set connections are made in ur tv,by what kind set up?Like by a RCA components cables Y,R,W RCA cable?Just follow the DVD player output holes hook up RCA cable Y,R,W to the DVD player out holes hookup to tv set input holes like Y,R,W input holes.Check the RCA connections cables pull out and re connected in those holes a couples times sometimes old equipment must do that for ensure contact are made.Might have a damage set of RCA cable set.Might have replace another RCA cable set.Or ur setup using a S-video cable set and used a RCA cable R,W cable only for audio only?Than S-video cable probally got shorted must be replaced.
Aug 04, 2011 | Panasonic Televison & Video
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Power on problem
You might have a cap that shorts after it heats up causing your problem. The whinning sound you hear sounds like the power supply has a short on it. Usually when this happens though, it doesn't go away until some part such as the horizontal output transistor is replaced. RCA's are notorious for flybacks shorting and then shorting the horizontal output transistor. Your flyback may be shorting intermittently. Strange! Stargazer
Feb 26, 2007 | RCA F25254GY 25" TV
RCA F25254GY 25" TV Logo
274 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
