Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool ultimate II water level problem
My washer will continue to fill with water until it overflows no mater
what size load I select.
    Sergeant:
    Champion:
  • 324 Answers
Does it still fill when you unplug? if it does then the fill valve is no good.if it turns off the check your hose going to pressure switch.will be a small clear hose going from tub to your pressure switch.
Posted on Nov 14, 2008
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Whirlpool ZUltimate Care II Washer, Model 3XLSQ7533JQ2. Washer keeps filling in the medium and the super wash level and will not go into the agitation cycle. Works on small load level only.
SInce the washer works ok on the small load size yet overflows on all others the problem is going to be with the water level switch and it should be replaced to remedy that problem.
The part number for that water level switch is W10339229 it could be purchased at your local appliance parts store or online at
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Oct 13, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer continues to fill and overflows
start to fill the washer,then turn it off,if water still keeps filling you have a bad inlet water valve,if it stops then check the water level water hose from the water level switch to the side of the outer tub-mike
Jan 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate Care II - water doesn't stop at the fill line, keeps filling to overflow and will not agitate
If the washer overfills, it may be something as simple as a detached or broken air hose on the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
The pressure switch on top loaders is located behind the load level selector knob on the operator console. The pressure switch on front loaders will be located inside the cabinet, usually mounted along the back interior wall. In the case of certain Maytag front loaders, the pressure switch is actually located under the tub. The principles of operation on all of them is the same, though. They all have an electrical connection and an air hose that detects the pressure from the tub as the water level rises.
If the pressure switch is not able to detect the water level properly, it will not shut off and the washer will never begin the wash cycle. Instead, you get a tub overflowing on your laundry room floor.
Read through the link provided and let me know if you have any questions. I hope this helps you.
NOTE: Another source of an overflow could be the water inlet valve. This is usually a slow fill fill that you find when the washer is sitting idle over night. A quick test to determine the source of the problem is to unplug the washer. If the water stops - pressure switch. If the water continues to fill - water inlet valve.
If you have questions, please let me know. I hope this helps you.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Fills up with water and wont stop
Bad Preasure valve comes to mind first and formost it acts like a level sensor balanceing the size indicated for fill.
Feb 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Fill switch cutoff
remove the 2 screws on rear of console pull console slightly forward and roll it up and back..ck small hose to water level switch to be sure it is on..is water stopping when control knob is pushed in?? if not suspect inlet valve replace it ..if it does suspect water level switch or that hose also hose may have small hole in it somewhere or be pinched
Aug 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
162 people viewed this question
Dan Webster
Dan Webster
Sal De
