Question about Frigidaire FRS26KF5C Side by Side Refrigerator
Making very little amounts of ice.
I have had the frigidaire unit for over two years and everything was working fine until yesterday. It started making very small amounts of ice (not enough to fill a glass). I switched the on/off lever to try and get it to work but nothing. The filter does need to be changed. The only other thing that has been different is that my wife has started using the crushed ice all the time. Water is going to the ice maker.
Installed a new water filter.
Posted on Nov 15, 2008
Why would my ice maker stop making ice?
Diagnostics does not tell you the water valve opens it only tells you the power was applied to the water valve
APPLIANCE 911
Jan 07, 2016 | Frigidaire Gallery Stainless Steel French...
I have a frigidaire LFTR1814LB. It has been leaking water from the freezer into the refrigerator section for about a month. A couple days ago it started making an obnoxiously loud vibrating sound...
Check if any piece of ice is stucked in thw vent and also check the thermostat of the refrigerator! When you close both doors you should hear the sound of the vent going fast
Nov 26, 2014 | Refrigerators
Freezer light, ice maker, and ice/water dispenser stopped working
did you replace the light . or just tighten it . and is ice cream soft . it sounds like the tempt is above 15 deg . and needs to be colder . this may be a control problem . but ck the little things first . clean the coils / make sure inside fan and under neath fan are going . re ck control settings . .. if problem does't go away . then look at control ..
Jul 29, 2010 | Frigidaire Refrigerators
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire FRS26ZNHD2-ice maker stopped making ice called Frigidaires 800# they told me to replace the 2 stage water valve did that still no water to ice maker
ice maker is bad has it,s own timer built in to let water in if you have water to your unit ,,, be sure the little lever is down on top of the ice bucket. if it is up this will stop the ice making process this i s a device to keep the ice from over filling the ice bucket
Mar 29, 2010 | Frigidaire FRS26R4A Side by Side...
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Everstar Ice Maker
Hopefully you have a filter before the ice maker. Replace this (if you have one) at least every 6 months.
ap
Jul 30, 2008 | Freezers
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS26KF5C Side by Side Refrigerator Logo
179 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
