Question about Gateway Computers & Internet
Twice now I've experienced a "stop error or blue screen" with the instructions that a problem has been caused by computer hardware. I was told to back up files to avoid data loss in case of a complete hardware failure. I don't know how to do that. And I was further told to contact the manufacturer to determine the specific component which is failing. That's why I'm here. HELP!
    Genius:
  • 1,913 Answers
Change your ram.
then try.
also if u have winxp boot able disk
bot wiht it then u repair xp
also checck your hard disk with "chkdsk /r" coomand .
then it fixes bugs.
Posted on Nov 14, 2008
Tip
How to Fix Blue Screen Errors (BSOD)
<p>Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.<br /> <p>There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.<br /> <p><b>How to analyze blue screen errors</b><br /> <p>The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.<br /> <p>Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.<br /> <p>Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.<br /> <p><b>The most common cause of blue screen errors</b><br /> <p>In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.<br /> <p>So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.<br /> <p>If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.<br /> <p>If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.<br /> <p>In most cases updating or reinstalling drivers will solve your blue screen errors.<br /> <p><b>Other causes of blue screen errors</b><br /> <p>However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:<br /> <p>Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.<br /> <p>Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.<br /> <p>Update Windows - missing updates, including service packs can be a source of stop errors.<br /> <p>Check your system - run a virus scan and spyware scan after updating your definition files.<br /> <p>Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.<br />
on Nov 29, 2010 | Computers & Internet
Blue screen problem on my HP smart touch iq 770 list of solutions
A Blue Screen of Death (BSOD), also called a STOP Error, will appear when an issue is so serious that Windows must stop completely.
  1. The most important Blue Screen of Death troubleshooting step you can take is to ask yourself what you just did.
    Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD.
    Undo the change you made and test again for the STOP Error. Depending on what change you made, some solutions might include:
  2. Verify that a minimum amount of free space is available on your Windows partition. Blue Screens of Death and other serious issues, like data corruption, can occur if there's not enough free space on your primary partition used for the Windows operating system.
    Note: Microsoft recommends that you maintain at least 100MB of free space but I regularly see problems with free space that low. I usually advise Windows users to keep at least 15% of a drive's capacity free at all times.
  3. Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
    Important: Make sure your virus scanning software is completely up to date and that it's configured to scan the MBR and boot sector.
  4. Apply all available Windows service packs and other updates. Microsoft regularly releases patches and service packs for their operating systems that may contain fixes for the cause of your BSOD.
  5. Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
  6. Check the System and Application logs in Event Viewer (7/Vista ' XP) for errors or warnings that might provide more clues on the cause of the BSOD.
  7. Return hardware settings to default in Device Manager. Unless you have a specific reason to do so, the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
  8. Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
    Note: If you've made several customizations to your BIOS settings and don't wish to load the default ones then at least try returning clock speed, voltage settings, and BIOS memory options to their default settings and see if that fixes the STOP error.
  9. Make sure all internal cables, cards, and other components are installed and seated properly. Hardware that's not firmly in place can cause a Blue Screen of Death so try reseating the following and then test for the STOP message again:
Aug 07, 2012 | Computers & Internet
Laptop crashes several times a day then get message "caused Windows to shut down unexpectedly and restart". Microsoft Windows Error reporting states a serious problem and is "Stop Error or...
Hi and welcome to Fixya
Stop or blue screen error are caused by recent software installation or hardware modification. If you installed software recently, try to uninstall the software and observed the problem. If you modify something o the hardware. I recommend to revert the modification and observe the issue.
Let me know if you have questions.
Have a good one!
Feb 25, 2011 | Packard Bell Computers & Internet
Blue screen appears at start up boot screen and restarts again
press "F8" while statrting , and then select "safe mode"
Feb 01, 2011 | Computers & Internet
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
I have an acer that will go to a blue screen after I type in the password then it restarts itself over again the same thing!
hope it helps, if so rate the solution
Nov 29, 2010 | Acer Aspire 3690-2196 Notebook
How do i fix my computer with a blue screen that keeps shutting it off?
Post your OS please!
Oct 01, 2010 | Computers & Internet
Stop Error (Blue Screen) XP/7000 VE/AGP
sounds like might be a bad card,
alternatively your system ram might be giving you grief, i had major BSOD issues with my computer and ram tested fine, upon switching sockets that the ram was in i found that it was actually good ram, bad ram socket.
Mar 05, 2009 | ATI RADEON VE (32 MB) Graphic Card
Blue Screen Error Message
dear,
check it by changing Ram. its mostly happens b'coz of Ram.
regards,
Jul 27, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
23 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
