Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
How do I use, paper port program
When I try to print from my cumputer, Using my Brother Multi-Function Center,There is a pop-up that say's "paper port". I do not know how to use the progam to print my document.
Please help me.
Paul Smith
    Genius:
  • 1,913 Answers
Go to control panel then printer and faxes select yourt printer.then right clik it properties.
thenn ports.
then selcet your printer port like usb .if u have .
if u have network porinter u must have tcp ip port.
if unot have then add tcp port.then give ip addresse of your printer then enable it.
Posted on Nov 14, 2008
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
Brother MFC-5440CN, unable to print
Unable to print is usually a paper jam either in the far right or the far left of the carriage assembly, you need a flashlight to inspect for paper scraps caught at either end of the carriage travel area.
Sep 04, 2009 | Brother Multi-Function Center MFC-240C...
Brother dcp 8060 reinstall paper tray error message
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center® DCP-8060...
Brother MFC-5860CN print unable 51 error message
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
I have a Brother MFC-665CW printer/fax machine. It jammed with paper and once I had cleaned it up the screen now reads, Unable to print 30. I can't do anything. Does anyone know how I can fix it please?...
Normal 0 In most cases it works. Worth a try.
Dec 15, 2008 | Brother Multi-Function Center MFC-665CW...
My Brother Multi-Function Center MFC-240C All-in-0ne Paper Jammed
how i can i plug mymulti-function center mfc model mfc240c to my pc
Dec 08, 2008 | Brother Multi-Function Center MFC-240C...
Mfc240 all in brother printer
i need the install utilities cd to program my mfc-240 machine
Sep 06, 2008 | Brother Multi-Function Center MFC-240C...
No paper fed
Brother printers dislike photo gloss paper, even if it is only 110gsm, they just don't seem to be able to feed it around the rollers. I suggest using a Matte paper, but no more than 140gsm
Jul 02, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
