Question about Daewoo DTS42 42 in. HD-Ready Plasma Television
Blue Vertical Line
I have charter cable with HDTV signal. The cable signal runs only through the cable box and then directly to the tv. there is a vertcal BLUE line about one inch inside the left side of the tv. Any idea what could be causing it?
  • 4 Answers
I agree with Lukster, 9 times out of 10 it's the plasma panel.
Posted on Nov 03, 2008
    Champion:
  • 217 Answers
Sounds like a panel defect or a loose ribbon cable, but more than likely it's the panel itself
Posted on Feb 17, 2007
SOURCE:
Was playing with the Playstation 3, when the kid unpluged it Vizo lost its color-turn on the cable (Charter) and it only shows 3 colors Pink Green and blue
If you are using the box for signal to the set unplug it for a while and then plug back in to let it reboot--may or may not solve the problem but easy and worth trying. Do the same with the TV if you want.
Jun 14, 2012 | Vizio L32 32 in. LCD HDTV
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
I have connected my Charter HDTV settop box to the strdh700 in the 'sat in' hdmi connection, then connected the 'out' hdmi to my sony bravia tv and the signal isn't getting there. any suggestions?
If you're not getting the audio signal, please select the Audio for HDMI to TV+AMP in Menu display. If you're not getting the videos, please check if the TV is HD ready and supports 1080p signals. Also check if the connections are firm and secure and you selected the correct input on both Receiver and TV. Please try connect the Settop box to different HDMI port of the receiver and try. You can also try connecting the Set top box to tv directly and check if its working. If its working fine directly with the TV, you may try to replace the cable and try else the receiver may require service
Sep 22, 2009 | Sony STR-DH700 A/V Receiver
Blue screen on tv
DID YOU TRY TO CHANGE THE CHANEL MANUALLY? OR CHECK THE INPUT BUTTON
May 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
Hi and welcome to FixYa,
Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
  • Charter Digital Cable > DVD/VCR > TV
If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
Pls post back results. Good luck and thank you for using FixYa.
Jan 26, 2009 | Televison & Video
What do I need to get for viewing HDTV
The TV you have will only process an HD via the component video connections. Your cable box needs to have component outputs and you will need to buy a component video cable to connect from the cable box component video outputs to the TV's component video inputs (should be 2 sets, #1 for up to 720p and #2 for up to 1080i...
Oct 28, 2008 | Samsung PCL5415R TV
HDTV Setup
it wont hurt to run both to the set, they wont interfere with each other
Nov 28, 2007 | Televison & Video
Moxi box hook up to to an HDMI input
You need the dvi to hdmi cable or the 3 colored component cables.
Sep 01, 2007 | Westinghouse TX-42F430S Television
Mitsubishi WD62530 62 in. HDTV LCD displaying blue vertical lines
i just got the same tv today and the same thing happend to me but it happend with the satellite input and i did not have the blue vertical lines i just had a black screen and sound. i unplugged the hdmi cable that carried the signal to the tv and plugged it back in and i had a picture. hope this helps
Dec 17, 2006 | Mitsubishi WD62527 62 in. LCD HDTV
Daewoo DTS42 42 in. HD-Ready Plasma Television Logo
83 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
