Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Tv went red and now power will not stay on
The color in the tv went to red smeared on the screen. After reseting the tv it will no longer stay on. Do you have any suggestions?
    Champion:
  • 225 Answers
If one color goes out of control, the TV will auto turn off for safety reasons. Sounds like a red bias resistor has burned out. A tech will be needed to trace this problem. Sometimes there is a knob behind the front TV speaker panel for adjusting the color bias levels. You could try to mess with it if you are able to find it. I would just get a tech. Could be a cheap repair.
Posted on Nov 14, 2008
Tv wont boot up
This is a prime case of bad capacitors in power supply. You may have only had it a year but how old are the parts that are in it?
Oct 30, 2017 | Televison & Video
Cant get tv to turn on
Try leaving it out of the power overnight. Also, check all the cable connections.
Apr 05, 2008 | Ultra LCD30-500 Television
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
Nov 23, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Flickering picture and color smear
Trash it Toshiba T.V. and laptops have a flickering problem with is caused by a failty power supply
May 27, 2009 | Toshiba 52HM95 52" HDTV Projection...
REAR PROJECTION TV NOT TURNING ON
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
Dec 29, 2007 | Akai PT5598HD 55" Rear Projection...
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
65 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
