Carrier weathermaker 8000
Its says auxillary heat is on what does that mean and why would it be on
  • 6 more comments
  • Crysta Wilson Nov 14, 2008
    I live in Oklahoma actually. I turned it up manually yesterday because baby was getting a bath and it had turned cold so i turned it up and then I thought I had tripped the breaker so I flipped it. Whenwill the regular heat come back on? I have it set for 70 and its at 68.
    I tried manually turning it up nothing happened. Also thank you so very much for trying to help me.
    something comes on but it barely blows and it doesnt get as warm as it should in the house. it feels like its blowing cold air.
    Boomer Sooner
    Thank you koolbreezes. Sorry to be a pain in your rear. I turned it up to 85 and no help. Why would it go on the fritz like that all of a sudden did I screw up the thermostat?
    How would I go about powering it off so it can reset itself, or do they do that?
    The air it is blowing is cold
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Hey Crystakwi, lets find out why with the informations you gave! this got to be a heat pump,-- up flow--you live in a cold climate--probably in the upper United States--! The Heat pump takes the heat out of the air down to 40*, then the auxillary heat kicks in , or you can just turn the thermostat to auxillary heat and it will kick in the back up heater, whethet it be gas heat --oil-- or electric heat to provide the heat from any degrees out side temperatures. Its cool , its just doing it job! Thank-you- very- much!
Posted on Nov 14, 2008
  • 1 more comment
  • Richard Craft
    Richard Craft Nov 14, 2008
    OK, aBoomer Sooner fan or an O S U cowboy fan? If this is charged up with freon right, it will heat the house with the temperature outside down to 40* , then the aux. heat kicks in. When the temperature gets back up, then the auxillary heat will kick out. theres a thermostat on the outside unit to call for aux. T Y V M.
  • Richard Craft
    Richard Craft Nov 16, 2008
    Hey again, if its blowing cold air , then check to see if the fan switch is in the auto position. cause when calling for heat, the timmer (after 90 seconds) kicks in, or the box heat up and close the fan switch,so that it don,t blow out cool air.---To reset it ,kill power at the breaker box and turn it back on.----! And when the outside temperature gets above 47* it should automatically go back to regular heat from the outside unit!
  • Richard Craft
    Oh yes, as to it barley blowing, check the filter to see if its clean or stopped up. But if the fan motor is barley blowing (the fan motor has 2 speed, hi--cool --- low--heat)Time for service call!
Carrier Weathermaker 8000...no LED lights on, but breaker is ok. Anything I can check before paying a ton for a service man?
This <a href="www.curthel.com">carrier</a>
has everything to quickly and safely deliver your <a href="www.curthel.com">car</a>.
Nov 04, 2013 | Carrier XHB123D X/Y Series Heat/Cool Air...
Where is the Flame Roll-out switch reset located on the weathermaker 8000 fro carrier?
outside the burners a little semi round thing with wires to it and a push button reset
most of the time they are on the louver above the burner
Dec 19, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 led stays on constant, blower works and i have power to the controller. no power at the ignitor/gas valve.
Check your thermostat level +29 and mode in Heat. If still problem, Check power
RV. Please write if your problem not solved with above solution. Thanks.
Dec 11, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Hello my name is veronacarrier 8000 weathermaker will not ignite
call the furnace repairman. you have a fairly easy repair but the parts are expensive
Dec 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
NO HEAT???? freezing
go to the furnace, there should be a service switch on the outside of the unit.  make sure the door is on good, does the blower motor come on?
Nov 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 8000 weathermaker filter
The filter should be located in the front there should be some kind of tab to pull out the filter.
Oct 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
416 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
