It may be almost impossible to find such a stand. I suspect that it was hung on a wall and then the original stand was discarded. You might try grundig customer service. I would also suggest exploring other options like rehanging the TV or having a carpenter fashion a replacement stand from wood.
helen366, if unit continues to do same thing, I suggest you contact Grundig for warranty service to put it right again!!! You must tell them that it should not have premature failure of the internal "switch-mode-power-supply" and they should replace the unit with new or refurbished same model free of charge.
12fixlouie
hello!since you have an experience in repair,try to have a voltage data on the circuits of your tv..check whether there is a supply output from the plyback secondary,does the heater of the picture tube is lit?if yes your plyback is working fine,,if not,check the horizontal output transistor for any leak,open or shorted.do it same to the regulator.if these two transistor is bad replace them..check also for any leak capacitors on your horizontal section.there might be a problem in there..same with the capacitors on the power supply section.If The plyback transformer is not switching replace the jungle ic.this ic generates the horizontal pulse to the plyback..good luck hope i helped you..
open your tv.At the back you see a plyback,it is big parts of tv with a wire attached to the picture tube,that is plyback At the buttom you wiil see a two knob, the lower knob is for the screen and the upper knob is for the focus.Adjust the lower knob or screen .
