Nothing on the tv responds except "power". I can't change the channel, adjust the volume, change video input, anything, by using the remote or by using the controls on the side of the tv
    Champion:
  • 225 Answers
There is a processor that takes care of all the TV controls. A tech will need to replace it.
Posted on Nov 14, 2008
Tv does not respond to any input only shows nosignal to any device
Did the TV's source get changed? If you use the Television remote and find the source or input button which switches between the video sources for your TV such as HDMI, A/V, Television Tuner,, VGA connector or Component video. If your using a cable box that remote only controls the cable box and possibly the TV power and volume but the cable box remote does not change the source input of the TV. Most Cable boxes rebroadcast their video on a specific TV channel and your TV must be set to that channel to receive the signal from the cable box. Let me know if this helps you out.
Aug 20, 2014 | Televison & Video
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
LG 37in HD LCD tv not responding to any pressed buttons.
Based on your description, it appears that you have main board issues with your unit since your controls do not work and some inputs are NG.
Apr 24, 2017 | LG 37LP1D 37 in. LCD Television
My TV was working fine and I pushed what I thought was the Volume on the side of it, but instead i changed the channel and now the TV is saying " no Signal" I think its as easy as changing the...
It sounds like you are on one of the video inputs of the tv. Look for a button that says input, aux, video, etc. on the set or remote.
Aug 27, 2008 | Televison & Video
Powers on will not change channels or video inputs
Is your remote programmed properly? If it is a universal remote, try setting it to one of the different codes for your brand. Sometimes the power and mute buttons and things like that are the same for all different types of a brand, yet all of the channel and volume things are different. If it's the remote that came with the TV, then I would try to get a replacement, as it could be faulty. Hopefully this problem is with the remote, and not the TV. Find if this is the case by using the volume/channel buttons on the TV itself. If they work, then you can be reasurred you don't have to call the TV repairman, and you will probably be able to fix this problem yourself.
Mar 16, 2008 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
