Once a file is corrupt it cannot be saved. (I have dealt with numerous Fallout and Skyrim corrupt saves on Ps3 if I could have saved them I would) Assassins creed black flag is known to have some problems with corrupts but i thought that they were patched (check to see if its up to date)
This is called texture map error and the cause is a lose of stream
data form the G.P.U. to the ANA/ HANA video chip giveing you strange checker board patterns on some surfaces .
The G.P.U. will need to be resoldered and clamped to fix
this problem . before it red rings on you
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
Normally this happens before the red lights of doom.
make sure the display adapters are properly plugged in and that you have the switch set to either hd or tv on the back of the xbox....also make sure the connection from the rca's to the tv are secure
it depends what game your playing somegames need a patch witch you can download on xbox live or chack your games to see if they have lots of scratchs or take the stuff of your xbox becuase it might be over heating
Mine did the same thing it kept freezing up, and then the red lights, I suggest go to youtube and there are a couple of fixes that you can do, thats what i did and it saved me from having to send my xbox in.
There are two possible solutions to this issue. One the data that you downloaded either got corrupted during transfer somehow or during a resent save. You should delete all the iformation off your hard drive and start fresh. If this doesnt work try takeing off your hard drive and playing a game if it deosnt freeze you will need to either try the delete method or get a new HD.
If this doesnt solve your issue then it is very possible that your system is headed for the red rings of death. My system was fried after i had played assasins creed. It would freeze up and create this checker pattern on my back ground my system shortly after went red ring.
