Question about Nike Triax Speed WR0085 wristwatch
Nike Watch not getting signal from fotpod
I have a Nike Triax 100 SDM that has been working well for about 2 years. I recently replaced the batteries in the footpod and the watch doesn't seem to be getting the signal for the distance in Chrono mode. The red light is flashing on the footpod, but the mileage isn't doing anything. Watch is keeping time and stopwatch works fine.
SOURCE: nike heart rate monitor triax c5
I was able to view the instructions here: (no title)
http://www.klokker24.no/ressurser/1183.pdf
Posted on Dec 27, 2008
  • 26 Answers
SOURCE: I need a new band for a Nike Triax Elite HRM Mens Watch SM0019-00
$20 Bucks about here
Posted on Jan 03, 2009
escapement
  • 2338 Answers
SOURCE: I need a wristband for my watch nike triax
NIKE contact address: USA 888-350-6453, Nike Timing Service Center, 7501 N.Harker Dr., Pearia, IL 61615, www.nikewatchrepair.com
Posted on Mar 28, 2010
SOURCE: turn off hourly beep on nike triax fury
Press the Start/Lap button in Time mode to turn on/off. This also turns on/off the beeping sound when switching between the different modes.
Posted on Jul 27, 2010
SOURCE: Can I run Nike Triax Elite software in Windows 7.
I had to take the following steps to get it to work in Windows 7 after running the setup executable under the Comments in the Windows row from http://www.ftdichip.com/Drivers/VCP.htm
  1. Open up Device Manager, right click on the Triax Elite and select Update Driver Software.
  2. Select "Browse my computer for driver software" in the window that pops up.
  3. Click "Let me pick from a list of device drivers on my computer."
  4. Scroll all the way down the list of "common hardware types" to USB controller.
  5. Choose FTDI from the list of manufacturers and choose the "USB Serial Converter"
  6. Confirm that you know what you're doing and want to install this driver.
Windows then finds another Unknown Device which is the serial port. Repeat as above but choose Ports for the common hardware types and then FTDI and "USB Serial Port".
Afterwards, run the latest Nike Triax Elite software (that you can download from http://www.nike.com/timing/extranet/elite_software/ and it should work.
Posted on Oct 14, 2010
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Nike Triax Fury works after replacing battery, but buttons wont work or change anything!
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Good luck.aa07e646-2c11-45e3-b8fa-b40ec2fd82c2.jpg
Flashing time display
Nike Triax Fury 100 Super
You need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Sep 08, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Stop screen flashing on nike trax fury
Yes you need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nov 29, 2011 | Nike Triax Watches
I have a Triax Speed 50 Nike watch and the local jewelry store would not change the battery because the possibilty of damaging the wrist band that needs to be removed. Any instructions on how I can change...
You can't change it yourself without doing damage. You will need to send into Nike or more accurately an authorized nike watch repair center that is close to you hopefully.
Nike customer service or a google search for authorized nike watch repair in XXX-city will get one close to you.
Dec 27, 2010 | Nike Timing Triax V10 Watch
Can I run Nike Triax Elite software in Windows 7. I have a USB driver problem.
Jan 24, 2010 | Nike Triax Elite Hrm/Sdm Heart Rate...
How to set a nike triax watch
Press and hold in the mode button the seconds should start to flash.
Press top right button to select hour.
Press set button to advance hour.
Press top right button to select minutes.
Press set button to advance minutes.
Repeat this for the month/dte/dy/yr
Press mode button when done
Mar 09, 2008 | Watches
Nike triax speed WR0082 regular
You must Re-Link the SDM pod to the watch after changing the battery. Go to the link below, It's not the exact model, but, should work, if not, go to www.nike.com and download the manual for your model.
GOOD LUCK
http://www.nike.com/timing/extranet/product/triax_elite/elite_manual_eng.pdf
Aug 25, 2007 | Nike Triax Speed WR0085 wristwatch
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Sep 16, 2006 | Nike Triax CV10 Wrist Watch
Nike Triax Speed WR0085 wristwatch Logo
57 people viewed this question
Top Nike Watches Experts
Arturs Kalnins
Arturs Kalnins
Kevin Getz
Kevin Getz
Are you a Nike Watch Expert? Answer questions, earn points and help others
