Utilizing the menu I try to select the channel list. Will display for 1-2 seconds and disappears. After many tries will occasionaly stay on and I go through the list and make sure 20 and 62 are 'YES' in the favorites column and 'NO' in the blocked column. Still will not show. I have used both A and B coax input connections and went through the Auto program channels.Other TV's using same cable feed are ok. Any suggestions will be greatly appreciated. Larry Collins
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning. [ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory. Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location. 1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button. 2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button. 3. Press the ENTER button again, to select "Country". 4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide) 5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected. 6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit the icon is not greyed out and tuning is possible.
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location. 1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button. 2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button. 3. Press the ENTER button again, to select "Country". 4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide) 5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected. 6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again. If the channel and other icons are greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location. 1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button. 2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button. 3. Press the ENTER button again, to select "Country". 4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide) 5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected. 6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again. If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Channel Edit makes it easy for you to save or delete channels in the list of channels in the TV?s memory.
1. Using the Number buttons, select the channel you wish to save or delete.
2. Press MENU to see the menu.
3. Press upper or lower key to scroll through the menu until SETUP is highlighted.
4. Press right key to enter the SETUP menu.
5. Press upper or lower key to scroll through the SETUP menu until CHANNEL EDIT is highlighted.
6. Press right key to choose SAVED or DELETED. Choose SAVED to add the channel to the TV?s memory. It will be available using the CH +/? buttons.
Choose DELETED to remove the present channel from the TV memory. To clear the menu press STATUS/EXIT. Or, wait a few seconds after you finish your adjustment; the menu will disappear automatically.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
I have the same problem, I cant watch channel 20 which is FOX tv here.
Any one help???
