Question about HP Computers & Internet
Trying to connect new printer wirelessly, cannot get past the wpa security key
    Scholar:
  • 132 Answers
You may need to verify the wireless security enabled in your router. Check from your router's setup page the security type and security key enabled in it to connect your wireless printer.
Hope this helps!
Posted on Nov 14, 2008
How do I change the security key of a wifi network on my Epson wf3640 printer
Wi-Fi is rapidly replacing wired LAN in homes and offices. This is the reason most high-end printers now come with Wi-Fi built into them. Now you can print documents wirelessly without attaching cables. However, before you print, you need to connect and configure your printer to print over a Wi-Fi connection. In order for the wifi to work, your printer and your computer must connect to the same wifi router or to an access point/repeater/extender connected to the same router.
1. Open Internet Explorer, on the address bar type 192.168.1.1
2. There's no username and type admin on the password. If admin didn't work, use your own password.
3. When you have the Setup Page open, click on Wireless Tab, then click on the sub-tab Wireless Security.
4. There you can see the Security Mode. If the mode is set to WEP, the WEP Key 1 is your wireless key. If the mode is set to the WPA-Personal, the Passphrase or the WPA Shared Key is your wireless key/PIN.try this steps and fix problems let if you have facing this problems call canon printer technical support Experts toll-free number 1-800-213-8289 for get online help. Epson Wireless Printer Support Number 1 800 610 6962 Help
Jun 25, 2017 | Epson Computers & Internet
I got a new laptop and am trying to connect to the internet, but it is asking me for the Network Security Key. I don't know where to find it. Can you help??
Network security key is a encryption key.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Apr 16, 2011 | Belkin Computers & Internet
My son, following instructions on a youtube video changed my security settings from WPA to WEP to connect his DS box. I managed to changed back to WPA but my network is down. No connection to my laptop and...
You will need to select your network, and "forget" it. Depending on the operating system you have the setting will be in a different location.
Sometimes just rebooting the computer and printer might be enough to reset it, but otherwise you need to input the key again because it would have a different identifier key number.
Apr 04, 2011 | Linksys Wireless-G WRT54G Router
Whats a wpa key? I have tried connecting to my router on my wireless device and my wireless device ask's for a wpa key? is it the same as a lan key?
WPA <<===>> WIRELESS PROTECTED ACCESS
You need to use an Ethernet cable to connect a computer to the router, and then access the web-server inside the router, and then run the "Wireless Networking Setup Wizard". When you do, you will set:
* the SSID ("network name") -- pick anything you prefer
* the encryption-level (hint: use 'WPA')
* the password for the network -- pick anything you can remember
Then, from a wireless device, do a "View Available Wireless Networks".
Select the SSID, and enter the password, to make a connection.
Feb 01, 2011 | D-Link DIR-615 Wireless Router
Cant get Internet Explorer on computermj
Greetings,
so you have a lenovo laptop, linksys wrt54g wireless router and a Lexmark wireless printer. And you wants to secure your wireless network. Just follow the instructions ---
SETTING UP WIRELESS SECURITY ON YOUR ROUTER--------
1> connect your lenovo with the WRT54G at port no. 1 it is very imp. to hardwire your computer, also check for the light status of the router to ensure that it is connected.
2> access the router setup from a web browser (may be using 192.168.1.1, the default address of your router, and admin as the password.). You can also go to kb.linksys.com if you need more help to access your router setup.
3> at the top click on wireless on the BLACK bar at the top.
4> under wireless click on wireless security on the blue bar.
5> select the security mode as WPA-PERSONAL (best encryption and supported by all devices).
6> select WPA ALGORITHUM as TKIP.
7> in WPA Shared Key type: "superman" or any thing else but it should be at least 8 characters long. and you should remember it as this will be your wireless password.
8> the Group Renewal key should be 3600.
9> Click on save settings at the bottom.
PERSONALIZING YOUR WIRELESS NETWORK NAME--------
1> Under Wireless, click on Basic wireless settings.
2> MODE: mixed
3> NAME: CHANGE IT eg NINJA, SPIDER etc
4> Channel: 11
5> SSID BROADCAST: ENABLED
NOW YOUR ROUTER IS CONFIGURED.
Now u jest need to connect your laptop and printer to this new secured wireless network using the security key and i am damn sure it will work.
Sep 12, 2010 | Computers & Internet
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
Lexmark wi fi printer need the wap code for the roter
If your wireless network is secured, the WPA or WEP security encryption key is a requirement to successfully connect the Lexmark printer to a wireless network. These keys (WPA or WEP), if you don't know it, can be obtained by accessing your wireless router through the computer. Your wireless router manufacturer or your internet service provider can better assist you in obtaining that info. Thanks.
Jul 26, 2010 | Lexmark Interpret S405 Wireless All-in-One...
Can't print
hi,
WPA keys is security key for ur network and when u run the wireless setuo wizard, use the key pad on the printer to punch in the WPA or WEP key.......
or
if u were using ur printer before wirelessly, then u should still have the ip address stored on   ur printer,
1) print network configuration by setup menu of the printer (setup>>network>>veiw network settings>>print network configuration page)
2)it will print out, in that u will have ip address.
3) go to priner and faxes, right click on the printer icon and go to properties and under ports tab, click on configure port and change the ip addres for the ip address wat u have if that doesnt work, click on add a port and select standard tcp ip port and new port at the bottom of the window and entry the ip address and proceed with that,,,,,,,,,,,it should resolve ur issue....
Regards,  raj_p5983
Jan 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
New epson Printer with WIFI asking for the PIN
You mean the wireless network key?
To get your wireless network key, do the following steps:
Dec 02, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
