Question about Frigidaire FGQ1442ES Gas Dryer
Frigidaire propane dryer that heats but then shuts heat off
Model # FSG748GFSO serial # XD83340144
dryer stars and then ignights and starts heating, but then after a coulple minutes the ignightor shuts off and there is no more heat, cloths come out still wet at the end of cycle, replaced thermostat on control panel but still not working, also checked thermo on vent line and checked ok, do you have any ideas what the problem could be??
  • ottiscornbuc Jan 14, 2009
    I have the same exact problem but mine is a whirlpool. It was tested and working fine at the shop but when I got it home it heated for a few minutes and then no heat.
    The worst is that I just tossed one that did the same thing but I thought that it was the machine/dryer. Now I am out of that dryer which was most likely working and I just spent hundreds on a almost new one and I still do not have a dryer!
    President:
  • 1,865 Answers
You have to troubleshoot the circuit components with a voltmeter to find out which part is failing. Most likely one of the sensors is failing and can easily be replaced. There is no way to know which part is failing without using a meter to test the parts while the circuit is operating
Posted on May 06, 2009
I have a Frigidaire Gallery W/D set. The model number for the washer is GLWS1339CS1. I need to dryer model # and the sticker is missing. Help?
Hi Joshua, I am happy to assist you!
I understand you are seeking the model number of your Frigidaire dryer because you are in need of the replacement part number of the heating element. Each appliance has its own model number listed in the serial tag on the unit itself. If the serial tag is missing or no longer visible on the upper front as you open the door of your dryer, at this point I would recommend reaching out to the manufacturer to verify if they have any documentation or your product registration. Best regards - Z
Mar 28, 2014 | Frigidaire Washing Machines
Frigidaire oven won't stay lit
sounds like you have to much propane coming out at one to ignight and flooding it can u adjust the level,of propane that will help unlell u ignighter is a slack one getting old
Sep 14, 2008 | Ovens
I have a Frigidaire Dryer Model#FEQ1442ES0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Frigidaire Electric Dryer
I have a Gas dryer that is a Frigidaire model#FGR231AS4 and serial # XD50912102 and the dryer does not heat up please tell me what I need to do to help my issue and how much to repair
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 31, 2010 | Frigidaire Dryers
Frigidaire gas dryer, gallery series model GLGQ2152ESO - no heat,
heatman101
Jul 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire dryer no heat thermal fuse seems ok? dryer is a 2005 model. model number and serial numbers worn off tag?
check your vent, make sure it is not plug with lent. If it is not then your heating elements.
Dec 06, 2009 | Frigidaire Dryers
Hello, My gas dryer FRIGIDAIRE with model
check exhaust ducts and inside bad of machine for lint blockage over heat shuts down heat if not igniter or gas valve failure likely
Jul 06, 2009 | Dryers
Whirlpool ultimate care gas dryer
the glow bar on the gas ignighter
Mar 15, 2008 | Dryers
Frigidaire FGQ1442ES Gas Dryer Logo
143 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
