Zenith Plasma I saw your post regarding the Zenith "pop" and you listed part numbers... Y-Sus - p/n# 6871QyH039B - $337.74 Z-Sus - p/n# 6871QzH044C - $244.68 Lower Y-Drive - p/n# 6871QdH089A - $132.48 Upper Y-Drive - p/n# 6871QdH088A - $132.48 Would these apply to a Zenith P60W26P 60in plasma manufactured in Aug 2003?
  • 5 more comments
  • Tyler Feltz Nov 14, 2008
    I get no picture, I do see a momentary glow of the screen when powered up but it goes black in less than a second. I have replaced x and y boards on other plasmas that were diagnosed bad but have never started from scratch trying to diagnose. There are no visible blown or leaking capacitors, not sure where to start next. I haven't found a repair shop that will test boards individually.
    Original post stated no picture but a glow when powered up that lasts less than a second. No visible blown or leaking capacitors. Trying to pinpoint before randomly replacing boards as I'm told some need to be replaced in pairs.
    power supply checks out good
    I will post results of testing.
    I will post test results
    I will test and repost results.
    Genius:
  • 1,239 Answers
Hi after disassembling tv you can see 2 tuners the left one is the picture tuner by adjusting it your problem will be solved
Posted on Nov 14, 2008
  • 899 Answers
Leaky capacitors are not as common as you would think , but bulging ones are and dried out ones are
the best way to check the capacitors without pulling them out of the circuit is to set the ohm meter to the highest setting , the capacitor should charge and hold and never become an open , but larger capcitors like on the power or flyback or oscilating circuit really can only be replaced ,otherwise extensive testing with a (555 timer) oscillator circuit and oscilloscope will need to be done to ensure that it doesn't have a leaky dc flow. because tv sets get hot , checking the solder connections on the most hot areas and resoldering suspected areas will help to eliminate possible causes
on these type of sets the surface mount components( in hot areas ) are the most likely culprits which are up there with the transistors and capacitors
you must be sure to positively eliminate the lamp , the door switch and the tuner , resolder just to make sure those can be eleiminated
that will be the best way to start determining the cause (elimination)
I will do some more research , but you must do some testing and post the results to better help to start the elimination process
  • 2 more comments
  • jason Nov 14, 2008
    ok I
    ok i will wait for your results
    if premtech can get you a service manual for this set , I would get it , I cannot get one for this set right now but I know what to look for , mostly looking for no power going thru a circuit is a good way , but having the schematic to check for the voltage readings listed on the schematic can help alot to find a problem
    but I'll be here waiting on those results , so i can further help
    electech
    here is his email if you want it , because i don't think you can see it anymore
    mailto:premtech@willapabay.org
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
did you check the power supply
try to check the power supply
use a tester!!
  • 934 Answers
NO - - the part numbers you have listed above are for the 50" line LG, yes basically Vizio uses them also in some of their 50" models, but is this the problem you're having with your Tv?? Before I spend that kind of wampum I'd get a couple of diagnostics done to determine what the cause is - - could save hundreds of dollars...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
  • William Rayburn
    William Rayburn Nov 14, 2008
    tylerfeltz,
    A couple of the guys above have some pretty good advice, you need to know what you're going after before simply shot-gunning the repair. It sounds to me like the power supply but I would test that before simply replacing it.
    Secondly, some boards, (IN SOME MODELS), do need to be replaced in pairs for greater reliability and off-hand I can't think of any in that unit unless maybe upper and lower y-drives or inverters.
    I do have the service manual if you want to email me privately and I can send it to you. Just please make sure to send enough info in your mail that I can know what I'm doing. I get nearly 3000 emails a day so "send me the manual" won't do it.
    Bill
    PO Box 442
    360-642-4993
  • 19,396 Answers
PLEASE DETAIL THE PROBLEM, OR GIVE REFERENCE TO ORIGINAL POST.
Posted on Nov 13, 2008
  • Ginko
    Ginko Nov 13, 2008
    6871QYH039B
    6871QZH044C
    6871QDH089A
    They are mainly LG/Vizio mamufactured parts, that also fit some zenith model. They should be OK , depending on your model.
    See
    6871QZH044C
    Contact the seller providing the exact model number, they will confirm if parts are OK.
    6871QDH088A
  • Ginko
    Ginko Nov 14, 2008
    If you have a glow and then raster disappears, it is often because of a faulty power supply, not because of a faulty sustain card.
    The capacitors must be tested to find out which one is faulty and generally it is better to replace the whole power board. Particularly if you are not a technician.
    To test a sustain card instead, you just start the tv without the sustain card and turn off after one second or so.
    If without the sustain card the TV has raster, then the sustain is faulty.
    Call Vance Baldwin toll free, call at (800) 432-8542 and enquiry about a power board for your model, I think part number you provided us are wrong. Part list for this model is not available online. Ask them the right part number for your model.
I have a 42" plasma zenith and not want to turn
The fix for this set is usually to replace the y-sus and z-sus boards at the same time. If you send them out you can have them rebuilt but usually only replacing one is only a temporary repair. I am very experienced on these, trust me. Sorry for the bad news. Good Luck, Russmann.
Apr 29, 2011 | LG 42PC3DC 42 in. Plasma HDTV
Black Screen
Checks the fuse at Y SUS board, if broken, change this board
May 19, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
My zenith plasma tv popped real loudlike a car backfiring and then the tv picture went black. power on green light wil turn on but it automatically cuts itself back off to the red light
There's an over current fault in the power supply or the Y-sustain convergence board. The loud pop was either a capacitor or pico-fuse breaking from excessive current overload. Sounds like 2 or 3 mosfets have shorted at the gate ends. Plasma TV's always have this problem because they generate too much heat and the components cant take the load conditions. Make your next TV an LCD...
To fix this problem have your local repair shop do it for you.....
any questions please ask.....
Jan 20, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
Heard a "pop" then went dead.
Sorry to say - it sounds like the 'pop of death'. The 50" Zenith plasma is very common for having a power failure issue. The problem resides in the Y-Sustain board in most cases. The Toshiba 50HP66 and Vizio P50HDM (as well as LG and HP 50" Plasmas) also have the same issue as they all use the same PDP Panel (plasma panel). The parts are manufactured by LG/Zenith Corporation. Since your Zenith is the model i'm thinking of (Z50PX2D), then the board you would need is the following:
http://www.discount-merchant.com/PCB-Y-SUS-MAIN-FOR-HP-HP-PL5060N-TELEVISION-p/2 761-hp-hp-pl5060n.htm
The above site is the ONLY place that I have ever found selling this hard to find part and the price is reasonable. If they are out of stock on that exact link, just search for 6870QYC004C on their site and you might find one that is in stock.
NOTE: Before making any purchases, please check the part and make sure it is what your TV needs. I am simply making recommendations and trying to point you to the right direction.
Dec 22, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
HDTV was ruuning & then popped. Then nothing
This is a common problem on these plasma TV's. The problem resides inthe high voltage boards known as the X and Y Sustain boards.. You canpurchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Jul 05, 2009 | Zenith Z42PX2D Television
I HAVE MAXENT 42INCH PLSSMA I HAVE NO PICTURE I DO HAVE SOUNE
HERE IS YOUR PART NUMBER 6871QYH039B Y SUSTAIN BORD AND CHECK WITH SHOPJIMMY.COM OR DEALTIME.COM THEY NORMALLY HAVE THIS TYPE OF PARTS
GOOD LUCK
Jun 23, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Loud pop then picture goes away.
bad upper, lower y sus & z sus pcb about 800 to 1000 to fix
Jun 05, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
50' LG plasma TV has thin lines running verticaly through tv
HI, this will happen when the power isn't distributed correctly, in return, depriving the main board of its needed current for operations. this will usually produce these lines. Replacing the power control board will fix this issue. LG Electronics/Zenith Part Number: 6871QYH039B
Jun 03, 2009 | LG 50PC1DRA 50 in. Plasma Television
Part # for a Y Sustain Board Cable Ribbon
why are you replacing it? what went wrong? mine just stopped lst nite and jsut ties to turn on. email res116@comcast.net
May 29, 2008 | Toshiba 50HP66 50 in. Plasma Television
MY Plasma Zenith TV went "POP"?
For those of you suffering with the loud POP and dead syndrome on this model the "guest" comments here are correct. The Y-Sustain, Z-Sustain and both the upper and lower Y-Drive boards are usually replaced at the same time to prevent any damage from taking out the Y-Sus and Z-Sus boards a second time. You might like to know that the original part numbers for both the Sustain boards have been changed since original manufacturing in an attempt to prevent this problem from happening again and these parts are NOT cheap.
Above prices do not include shipping or sales tax if applicable.
Unfortunately techs have little voice in trying to get the manufacturers to correct these problems before the warranty runs out - knowing that after warranty repairs are going to be met with quite some resistance when it's coming out of the consumer's pocket.
Also, for reference, I've done about half a dozen of these and all have been under some warranty or extended warranty. Labor was approximately 6.5 hours so you can plan to spend roughly $1400 - $1600 for this repair..
Thought maybe if I posted here it would help a few find the answers they were looking for..
Bill
Nov 17, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
