Computers & Internet Logo
A
Anonymous Posted on Apr 16, 2012
Can i boot on usb with qosmio g15? - Toshiba Qosmio G15-AV501 Notebook
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Aug 30, 2008
SOURCE: Toshiba Qosmio G15-AV501
See the below "copy & paste from another member" I don't know how sucessful these other owners were, but it's worth a try:
PNWSolutions
Rank:master_s.gif Master
Rating: 77%, 15 votes
I had the same problem, what you need to do is call Pamela Saunders at Toshiba Corporate in Irving, CA and she will get it repaired for you at no cost to you regardless of warranty. This is a bad batch of computers.
The Phone Number is: 800-457-7777 or 949-462-6000
dcolvard
Dusty Colvard
  • 65 Answers
  • Posted on Mar 21, 2009
SOURCE: forgot bios password
On some models of toshiba laptops they can only be reset by a toshiba laptop repair center. I believe your laptop is one of them. How it works is when you turn the laptop on there is a special keycode combination that you push and then you have to call advanced technical support and they give you a special code back to unlock it. Advanced Technical support will only talk to Toshiba repair center techs.
Hope this helps. Toshiba Customer Service 1-800-457-7777
benwabnick
Ben Wabnick
  • 2404 Answers
  • Posted on Jun 08, 2009
SOURCE: New hard drive for my Toshiba Qosmio G15 R laptop
I believe with Toshiba they normally would give you a recovery disk and then a drivers and utilities disk as well. If you don't have both then I would suggest installing windows xp and then go to this page:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=835452&rpn=PQG10U&modelFilter=G15-AV501&selCategory=3&selFamily=804517Click on the downloads button and from there choose your operating system and you can download the drivers from that page.You'll know which drivers you'll need by going into the device manager and seeing what has a yellow question mark next to it.If you need more help with this let me know and I'll help you more.
Anonymous
  • Posted on Feb 23, 2010
SOURCE: Toshiba Qosmio G15-AV501 will not boot
Subscriber/user FMFM85 had posted a solution for another laptop that worked for me. That was Power down, remove battery, remove power, wait five minutes, plug in power and do not install battery, I rebooted to last known good configuration. This method got me further along.from the absolute DEAD state the laptop was in. Now I know that the laptop is really hosed in other ways. I will keep you posted.
Anonymous
  • 185 Answers
  • Posted on May 25, 2010
SOURCE: when i turn on the computer i here the hardrive
Screen not working
are you able to hear the windows log in?
if you do but no image, most likelly your video card is ruined. overheated or dropped maybe? don't worry is bad but not that bad, there is a way to fix that by a professional.
take it to a computer repair shop and have them check the video card ask if they have a rework station or someone who may they have to unsolder about 50 pins at the same time get a new card and solder it again.
sometimes they apply heat to it and it will work again but for just a few days maybe weeks but it goes bad again. so replacement is the best option.
I used to charge about 250 bucks but you may be able to ask for a rebate.
do not take it to a major computer store they would tell you there is no repair so you can go in and get a new computer
if it works for you don't forget to rate me
thx
2helpful
My laptop wont start its a toshiba g15
have you tried pulling each stick of ram individually?
if there is still no boot then its safe to say that the motherboard or one of the two video cards has failed. its a pretty common on the qosmio g series
Toshiba G15 laptop has green lines and will not boot past Windows logo, it freezes there. Can anyone help?
reboot in Safe Made by pressing F8 at boot up. Then restore the system to an earlier date. This may be happening due to some malicious prog that you have installed or due to a virus. If due to a virus, the install AVG Anti Virus free from www. download.com.
1helpful
1helpful
2answers
Hard drive not showing in bios
It appears that your #2 hard disk has died. To test if it is faulty, remove the #2 drive and connect it to an USB hard drive adapter and plug it into the USB port of a working computer. If the computer see it as an external USB drive and you can see the folders and open the files, then it is OK and the fault is possible the disk controller.
If the hard drive is not recognised then it is faulty and needs to be replaced.
1helpful
3helpful
4answers
I have a Toshiba Qosmio G15R and I need drivers
I went to the Intel site and downloaded the Intel® PRO/100 VE Network Connection driver here. It worked great. Now if I could find the right audio/multimedia drivers I'd be happy. Hope this helps.
My daughter put a password for the bios and cant remember it.
Try holding down the "Left Shift Key" when turning on the system
1helpful
3answers
Nvidia Gfofce FX
2answers
Qosmio g15
Could you explain this problem just a little more?
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
