Question about Mitsubishi WS-55511 55" Rear Projection Television
Convergence way off!
Hi!
So I had the green line issue as mentioned in this post
http://www.fixya.com/support/t371268-green_lines_upper_third_screen
I replaced the convergence IC, and the green lines went away, however now the convergence is way off, and it looks like a fishbowl.
Is there something else broken? Anyone have any idea?
  • 1 more comment
  • b_pgawannabe Nov 13, 2008
    Here's a picture of the advanced convergence screen..
  • b_pgawannabe Nov 14, 2008
    I just put a new Convergence IC in it...
  • b_pgawannabe Nov 19, 2008
    Also, the Pico fuses are all fine, none are blown!
    Also the Diodes in line with the fuses are fine.
    Any other ideas?
    Champion:
  • 225 Answers
Yup, you lost convergence. The only fix is to repair/replace the convergence IC. Some techs will just replace the whole video board.
Posted on Nov 14, 2008
What will cause a wavy blue lines running left to right from the top down
That is knon as a convergence failure. Its real common an a failry easy DIY fix. You can read more about how to fix it here in this video and on the fixya tips page below.
07e70208-1f08-4826-857e-065c46e4dbb8.pngFixya Tip Page
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 15, 2013 | Philips Televison & Video
The green is out of line. i tried the convergence but its too far out of line, also the line is crooked.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 03, 2011 | Hitachi 43UWX10B 43" Rear Projection...
RCA 52 in HDTV red, green and blue colors not alligned - concave
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA D52W19 52" Rear Projection Television
Rear projection convergence issues
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 24, 2009 | Sony KP-53V80 53" Rear Projection...
Green is out of line
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 15, 2008 | Panasonic PT-53TW53 53" Rear Projection...
My screen have some red lines
Sounds like convergence amp ic's
i dont have any part number for that model.
good luck
Mar 11, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convergence off
good luck
Mar 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
I haved a 50h71 toshiba with red and green line running vertically on screen. Please help in solving.
· http://www.mouser.com/index.cfm?handler=home
· http://www.mcmelectronics.com
· http://www.bdent.com
· http://www.electronix.com
good luck
Feb 20, 2008 | Televison & Video
PT47WX52F Convergence problem, 3-d look, green worse
good luck
Feb 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
141 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
