Question about Water Heaters
No hot water
It's a bosch hot water heater that produces no hot water and flashes an A 2 on the front panel
  • 107 Answers
Got to the following web address and find your heater.
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/tabid/334/Default.aspx
This is the same site we use @ our company.
Posted on Dec 18, 2008
Bosch AE125 no hot water, blinking light
Hey Andy. Do you have your owners manual? There should be a section near the back that will break down the diagnostic code the flashing light is giving you. If not remove the front cover and look inside should be a wiring diagram and light legend.
Dec 14, 2013 | Bosch PowerStar AE125 AE125 Whole House...
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Sep 24, 2012 | Bosch PowerStar AE125 AE125 Whole House...
A2 code appears and there is no hot water in the house. what should i do?
Problem with overheat cutoff. Press reset button on the control panel.
Before calling service technician, open following link for Bosch troubleshoot resources.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Recommend that people not install tankless water heaters, or heaters they cannot repair themselves since all costs are energy.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 04, 2012 | Bosch Water Heaters
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch aquastar Aq125-hx does not produce hot water. Pilot is ok. Gas and Flame heat is ok. water pressure is ok. Just no hot water getting to the faucets. Help.
That particular tankless water heater has hydro-generated ignition. In order for it to function, it requires a certain water pressure and velocity. You can try turning on the hot water in two location in your house to see if that gets it started. If it does, try getting a higher flow shower head, or removing the limiters in your faucets.
Jan 07, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Cannot get hot water
Make sure breaker is turned on. If that isn't it tell me model number and maybe I can help you more
Feb 07, 2010 | Bosch & Tankless LP Hot Water Heater
My hot water heater is not producing hot water. Flashing code EA
hi i think your problem is with a dirty connection on one of the three electrodes they are situated under the black plastic air intake in the bottom half of the unit take them out and clean the connections with fine sandpaper hope this helps
Dec 03, 2009 | Bosch & Tankless LP Hot Water Heater
Not producing hot water
the only time it's the valve is when you loose pressure on the hot side of any faucet, depending on the age of it you could just call the company bosch and they will tell you how far away a real tech is from you and contact them for you, you do have a 1 year labor 5 year parts warranty with the tankless unit, for you I hope you are within your warranty,,,, if not change it to a rinnai system the will send people to you if you have a problem
Jun 05, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Sings when producing hot water
it is a loose washer in a valve,,, when the water hits it just right it makes the sound,, either check the valve by turning it on and off while water is running that will let you know wich one it is
Apr 19, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Water Heaters Logo
249 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
