I have a 3 year old Panasonic CT-32HXC14J TV. It has been working fine until today. When I tried to turn it on the internal (6.3amp/125v fuse) blew.
I went to get a new one and could only find a 4 pack...
Hello sjday62
It sounds as if you have a component that has changed value enough in value to cause a high current draw, but has not completely shorted out. this phrase from you "so I did a stupid thing and bypassed the internal fuse and it turned on and worked" Not as stupid as you would think because it confirms what I said above, the 6.3 amp fuse tells me that the current draw normally is about 3 amperes since the normal rule of thumb is to double the value of the current to select the type of fuse. a five amp fuse should as well as a 4 amp fuse (it's best and recommended to use the exact fuse type). Now back to your issue. I would suspect that a transformer in the power chain has developed a shorted winding, or a capacitor begun to develop a short or excessive absorption.
I would suggest that you have the set looked at by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
