Question about LG LH-D6230 System
LH_D6230 The dvd works but after a bit it overheats and turns off , taken apart fuses ok took fan out put power though it that works. when power on no power to the fan when checked with meter.
  • Midge_ru Nov 23, 2007
    Battled to get all speakers working when I bought it.
    Salesman 'fixed' this, but didn't give instruction manual back.
    Now I have an intermittent problem. Basically:-
    DVD mode: plays, but sometimes skips or hangs.
    CD's: plays then same as above - hangs.
    Sometimes plays 12 tracks then starts skipping.
    Sometimes plays for 42 seconds.
    Sometimes plays for 1 min 21 seconds.
    Assume it is overheating, but as I said then why doesn't it do so on the DVD & why does the run time differ before hanging? Can play a whole DVD without any problems sometimes.
    No display of tracks on TV screen, yet cd spinning.
    Sometimes makes awful sound when ejecting almost as if it is still spinning when it opens & then scrapes disc.
    Initially I assumed it was a drirty lens causing the problem.
    I tried cleaning the discs first, then a number of cd & dvd lens cleaners to no avail. (CD Warehouse's house brand dvd/vcd/cd-rom/cd cleaner & Philips DVD lens cleaner-SVC520)
    Help please!
    Midge (midge@polka.co.za)
I had the same problem thought it eas overheating so opened up to check fan and found IC500 on main board had faulty soldering. Solder pads were u/s so had to solderlinks to IC legs. Seems to have fixed it butI noticed fan not turning can someone help me on this is it supposed to be going all the time or is it thermastatic controlled?
Posted on Apr 29, 2009
PROBABLY IT HAS A POWER SWITCH SELECTOR ITS BACK. IT'S NOT WRITTEN WHICH POWER SYSTEM SIDE, BUT IT'S WRITTEN ON INSTRUCTION MANUAL. SO YOU CAN SELECT TRUE POWER REGION AND IT IS ABLE TO WORK ON REGION..
Posted on Apr 02, 2007
I purchased a LH D6230A system in Malayisa. When i got back to Canada and tried to use it i noticed it was 220 volts, 50 Hz. which we don,t have in Canada. Our power is 120 volts ,60 Hz. What i'm looking for is a main transformer for this unit so i can use it in Canada. Is there a place in Canada or the US where i can purchase this transformer...maybe you can give me a part # for it. Thank You Kindly Charlie DeG.
Posted on Feb 07, 2007
The spin motor is in short !!!
Posted on Jan 16, 2007
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | LG LH-D6230 System
LG DVD player LH-D6230 - displays "dvd error" soon
Eprom corruption. Replace eprom, and edit in mode service.
Jan 07, 2011 | LG Audio Players & Recorders
Cannot record t.v. programmes after the changeover on video
I put the recorder channel on AV2 and then recorded it. It worked. Thank you anyway.
Dec 29, 2009 | Samsung SV-DVD55 DVD Player / VCR Combo
Audio playback
1.bad rca jacks
2.could be connected to wrong audio lead rca jack
3.the settings in dvd player donot match the receivers example- dts or ntfs
4.make sure its regioned to your player some audio isnt on the disks
5.pc's usually have new cd formats that came out
cd's and dvd's for some reason in this age isnt being able to play fully in older equipment do to the change in cd/dvd formats which makes you go out and buy new equipment it happened to me not just 2 weeks ago bought a new dvd and found out it wouldnt play in my year old dvd deck had to go out and buy new dvd deck then disk and all my others played fine
May 11, 2008 | LG LH-D6230 System
Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Jan 16, 2008 | LG LH-D6230 System
LG LH-D6230 DVD
I had a similar problem coming from South Africa to Australia and had to change the regional code setting.
Change to multizone format:
1)Ensure no disk in unit
2)Unplug unit from AC supply
3)Plug unit back into ac supply
4)Use remote control for the following commands:
5)Press the power key, the unit will come on
6)Wait until no disk appears on the display
7)Press sequentially the keys: PAUSE;3;1;4;1;5;9
8) "Code" will appear on the display
9)Press 0 (multizone)
10 Press sequentially the keys: PAUSE,POWER
11)The unit will turn off(standby mode), leaving the new regional code programmed. If you do not succeed at the first attempt disconnect the unit and repeat the above steps (1 to 10)
Hop this helps
Susan
Jan 12, 2008 | LG LH-D6230 System
'Where can I get an LG optical pick-up for the LG LH-D6230 DVD player?
Easy and inexpensive to repair. not laser at all. disks are not spinning at the correct speed, clean the round rubber seal that pushes against the disk with 100% alchohol.
Apr 19, 2007 | LG LH-D6230 System
IS POSSIBLE TO UPLOAD DIVX PROGRAM (PATCH) ON IT ??
Try this:
http://www.videohelp.com/dvdhacks?dvdplayer=D6230&hits=50&Search=Search
Apr 18, 2007 | LG LH-D6230 System
LG LH-D6230
The life of LG optical pick-up is Aprox.1000hours if it is more then 1000 hours used then just replace optical pick-up.
Feb 07, 2007 | LG LH-D6230 System
LG LH-D6230 System Logo
445 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
Mike Duncan
Mike Duncan
pankaj rautela
pankaj rautela
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
