Question about Toshiba 40H80 40" Rear Projection Television
TV Suddenly Stopped Working With No Warning Signs Of Impending Failure
My tv was working fine the night before & when I came to switch it on again, it did nothing else but illuminate the red power light and the green light started flashing, ( this green light is above the time clock icon ). Any idea's?
  • DJspikeman Dec 07, 2007
    Same problem on my 46WH08 which uses the c00p chasis. The shutdown circuit is not allowing 5v on pin 16 which would fire the unit. If I short 15&16 together then it fires up ok.
    Toshiba have a fault finding guide but there is a second one that describes my issue and that is missing. C00p chasis fault finding guide 2.
I had the same problem and was advised...
Check the 2amp pico fuse at F470 and if open replace it and Q404 2sc5570 the HOT (horizontal output transistor).. If not open check HOT for short EtoB and inspect the solder connections of Q801 in the SMPS.
If any of that sounds greek you need to take it to a shop or find someone handy with a meter and a soldering gun that can do the work for you.
If you've had yours fixed can you please let me know as mine is still not working
Posted on Dec 23, 2007
My Samsung TV will not turn on.
Could be an open internal fuse or power supply failure
Apr 23, 2018 | Samsung Televison & Video
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
Sound through only one speaker
Check the other speaker which do not work. In most cases, the speaker is found faulty. If so, replace it with a similar one.
May 07, 2013 | Televison & Video
The sound on my TV has suddenly stopped working
check all wires are firmly in place, especially the scart lead, and just give them a little push to make sure, if that doesnt work, try unplugging your tv from the mains and wait 5 mins, plug it back in, wait another 5 mins, and turn on, if that doesnt work, contact the company's customer service line.
Mar 17, 2012 | Sharp Televison & Video
The tv suddenly stopped responding in the morning i was using it with the ps3 and in the night i came home to play again and the tv is just black, no video, however the led is green, no buttons respond and...
Please connect the cable connections and cable again. Best way is to switch off both the machines. Wait for sometime. Reconnect them and switch on. It should work if no part is damaged.
Feb 14, 2011 | Televison & Video
It suddenly stopped working. It is 3 yrs old.
i restore my opperatting sistem and cant access my drivers again
Aug 31, 2009 | Dolphin Maytronics Diagnostic Robot...
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Jul 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Toshiba television
the symptom is caused by a breakdown in power supply or the horizontal deflection circuits. have it check by a qualified service technician.
Jan 13, 2007 | Toshiba 27AF41 27" TV
Toshiba 40H80 40" Rear Projection Television Logo
107 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
