Question about Electrical Supplies
Need to replace socket in Hi hat ceiling fixture
In order to replace the socket in one of my hi hat ceiling fixtures, I need to remove the housing from the ceiling. The fixture dates back to 1987 and the flange that sits against the ceiling is an integral part of the fixture itself.
There are no spring clips holding the funnel shaped housing in place. Looking into the housing, you can see three cross shaped punch outs that seem to serve no purpose. The socket itself is attached with 2 bolts to a metal cup, that sits in the narrow back end of the housing. (The bolt heads are not visible since they are on top of the cup.)The metal cup has 2 springs that snap into holes in the housing. The cup can be pushed up a little, but not down.
Pulling down on the flange just seems to bend it and I am reluctant to break open the ceiling.
I'm out of ideas. Am I missing something? Can anybody help? Norm
  • nlatner Jan 04, 2009
    This problem is about a light fixture, not a fan.
  • Kenneth Crowther
    Kenneth Crowther May 11, 2010
    the socket has two clips that squeeze together that should release it from the trim or what I think you are calling the funnel. But I would like to know what brand name you have. Some of them twist to a point of release. Is it halo, light o lear, etc..
    Problem Solver:
  • 19 Answers
Do you have a discription? In order to get to the main wires of a flush mount fan turn off power to fan, remove Lt kit if applicable, Take off blades. Does this sound right ?
Posted on Jan 04, 2009
I have a 4 pin compact Florissant hi hat want to put a screw in led bulb any ideas
check DIY on the internet. It seems I saw a conversion kit for a high hat fixture on a "This Old House" TV program or "DIY" TV program.
Oct 22, 2014 | Home
Replacing a light fixture
This is much simpler than it sounds, but if you're a total novice you'll need to read it all.
First, make sure power to fixture is off. Best method is to locate circuit breaker or fuse that controls that fixture's power. At minimum shut off the wall switch to it if there is one.
Next, remove the old fixture. Usually there are two screws or decorative nuts holding the base cover (canopy) on. On ceiling pendant fixtures there may be a retaining ring holding up the canopy, unscrew this ring counterclockwise and the canopy will drop over the support chain, exposing the junction box where the wires are connected.
It is critical at this point that the power is off.
Modern house wiring and fixtures are connected with three wires.
Green or bare copper = ground (earth)
White or grey = neutral
Black, Red, Blue or any other solid color other than green, white or grey = power or hot wire (this is the wire that is controlled by a switch.
For simplicity I will call the three: Green, White and Black.
The next step requires you to carefully pull the wires out of the junction box and isolate the black, white and green wire connections from each other. Make sure the connectors (wire nuts) for each connection are accessible.
Warning: With old or over heated wiring, take extra care not to crack or disturb the insulation(wire covering) on any of the wires. If insulation is crumbling away exposing bare wire, stop and call an electrician! Do not turn the power back on until he has repaired those damaged wires, they could start a fire.
Isolate the connection between the black house wire and black fixture wire. Remove this wire nut. At this point I usually use an electrical tester to double check that the power is off by touching one side to the newly exposed black connection and any grounded metal part nearby.
(Note: some multiple switched (three way) circuits may use a white wire as a power wire. If the black fixture wire is connected to a white house wire, mark that white house wire with black electrical tape for future identification.)
Once you are positive there is no power at the fixture junction box remove the connectors from the white and green wires.
Detach the old fixture and it's mounting bracket.
Re-attach the new fixture using bracket and new connectors that are usually provided. Some brackets have a green ground screw. Wrap the bare ground wire clockwise around that screw and tighten it down leaving enough remaining ground wire to attach to the fixture ground.
If the wires to the new fixtures do not have a 1/2 inch of exposed bare wire at the ends (stripped) you must do so. I use a wire stripping tool but you can do it with a sharp knife being careful not to nick the metal wire.
Once the wire tips are stripped, hold the tips of each color pair together side by side, slip the wire nut over them and twist clockwise until snug. (White to white, black to black etc.)
Take care that the new wire nuts are secure at each connection. Do not over tighten them but insure that they are correctly attached by gently tugging on each wire. When completed the black and white connections should have no exposed bare wire showing.
The Green (bare copper) wire is there for safety and never carries current, hence exposed wire is not an issue on ground wires.
Assemble and attach the new fixture according to instructions in the box.
Pendant ceiling fixtures usually require additional assembly steps including adjusting chain height, looping wires through the chain and slipping retaining nut and canopy over chain prior to connecting. Always follow directions that come with the fixtures.
When in doubt, call a professional. Electricity is dangerous.
Apr 06, 2013 | Dryers
Replace GE 50W Halogen bulb in ceiling fixture
if fixture is as shown, remove the nut in the middle of the fixture, remove the lamp, and replace it, note donot touch the lamp with your fingers, this causes lamp to fail, use a cloth to install then replace in reverse as you took it apart
Sep 27, 2011 | Universal Lighting and Decor White 11"...
I need a diagram to install a Westinghouse 3-way light switch (#77052) on a lighting fixture on the bottom of a ceiling fan. I did not do the removal of the light fixture so I don't know how it was wired...
If by a 3-way switch, you mean a switch with 4 steps of brilliance: off, low, medium, and high when used with a 3-way bulb. The black wire of the switch is connected to incoming power wiring hot wire. Most often also black. The red switch wire connects to the center contact of the lamp socket. The blue wire connects to the small pin connection that is physically between the center connection and the screw shell of the lamp socket. The screw shell is connected to the incoming white wire of the house wiring.
Dec 30, 2010 | Westinghouse Electric Ceiling Fan 3-way...
How do you take the light fixture apart to fix the balace?
You may find that a new fixture is the easier and cheaper way to go as some ballast can be expensive and hard to find the matching style. A similar style fixture at Home Depot or Lowes cost, in a 2 pack about $18.00. Add a CF bulb to it for another $4.00 and you have a decorative similar fixture. Some ballast cost anywhere from $9.00-$50.00. If you wish to replace the ballast: (turn off the power) remove the globe, remove the existing florescent bulb, take the fixture off the ceiling (usually two screws) remove the wire nuts, make a small diagram of the existing wires and the color codes, take the ballast to the Home Depot or Lowes first, match the ballast. Now reverse the process to replace the fixture. Hope this helps. Good Luck!
Douglas
Oct 31, 2010 | Universal Lighting and Decor White...
Both the fan and light have ceased to function!!!
As an electrician, this is a fairly common problem with any kind of fixture - not limited just to paddle fans. The problem is likely a loose connection in the ceiling box, or even elsewhere in the circuit, as the chance that both the fan and light failed at the same time is very slim. Since the fixture is a paddle fan - when it is operated it causes movement and is a dynamic load - as a opposed to a static load that a non-moving simple light fixture would present. The constant movement can loosen a connection over time. Before we go any further, operate any speed control / light switch on the fixture itself to make sure they haven't been accidentally set to the off position.
Shut off the power. Loosen the screws on the cover or canopy that that will allow access to the wiring compartment in the ceiling. LOOK for anything obviously loose. You may need to have someone hold the fixture once you remove it from the hanger to see the connections - or simply disconnect the fixture wires from the house wiring completely. There may be 2 or 3 wires besides any bare or green ground wire that supplies the fixture. Photograph or otherwise mark the wires before removing the fixture wires.
Turn the power back on, and use a tester (preferably a meter) to see if power is present on the ceiling box wires that supplied the fixture. If present, the problem lies in the fixture wiring or individual fan / light pull chain switches. Wires do not fail along unbroken lengths unless cut. They will fail at places they are joined together. There may be a wiring compartment in the light fixture that has a loose connection. Inspect for loose or bad connections with power off and continue testing as above until you isolate the bad connection.
If there was no power in the ceiling earlier when the power was restored, there is a break elsewhere between the power source and the ceiling box. You'll have to look in switch boxes and outlet boxes in the room and possibly adjoining rooms to find the loose connection. It may even be in an adjoining room's ceiling box, too. This is a labor intensive job - and can take some time to locate and repair. Take your time and only turn power on when ready to check for the presence of power.
Of course, you could call an electrician to do the work for you. I hope this was helpful - good luck!
Aug 10, 2010 | Hampton Bay 52 In. White Redington...
In changing out an incandescent light bulb in a ceiling mounted light fixture, the glass hanging pendant was loose, so I removed the fixture from the ceiling, leaving the wiring connected, and tightened...
Many times with very old wiring the wire can break inside the coating and not be visible. To check for sure what has happened you will need an electric tester. You will need to check for 120 volts acros the two wires with the switch on. If there is no power, then check at the switch. If there is power there then the wire is broken.
Replacement of the old wires in an old house is very difficult and you will probably want to hire a professional to do that.
Heatman101
Feb 28, 2010 | Hampton Bay 24002 Ceiling Fan
Toyota avalon headliight lamp replacement
there is a single phillups screw that hold the turn signal housing to the head lamp. remove this screw. after that the turnsignal housing will be loose but act as though something is still holding it. I usually take a small flat tip screw driver and place between the headlight and turnsignal housing about a quarter of the way down and pry the turn signal housing forward and out at the same time while puling with my free hand. Since this lamp fixture is difficult to get a grip on, the flathead screwdriver is used only to help pull the lamp fixture from the fender. After the fixture is in the open the actual lamp socket twist locks into position from behind. once the socket is removed the bulb simply slides straight out from the socket. Installation is reverse of removal.
May 30, 2009 | 2001 Toyota Avalon
Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Electrical Supplies Logo
1,127 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
