Question about Onkyo Audio Players & Recorders
Tx Sv717 Pro Onkyo reciever. The display stopped working, but everything else is OK. The controls still work perfectly, but my wife cannot tell what she is doing, and the divorce will be more than the repair or replacement.
  • Rusty Beaver May 07, 2009
    I have repaired the problem.
    Burned up a resistor feeding the display.
    Replaced with a higher wattage resistor, problem solved.
  • 21 Answers
SOURCE: Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Posted on Sep 03, 2007
  • 239 Answers
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Posted on Mar 06, 2009
smarthome2
  • 1114 Answers
SOURCE: Onkyo TX-SR606 Reciever - 20 sec after power on, screen is green
The HDMI version in your receiver is 1.1 or 1.2 which will not pass video as it should. It's not Onkyo's firmware at issue, it's HDMI and in all receivers up to 2008 model year this is a very heated problem! The only fix is to run FIOS directly to the TV via HDMI and run it's audio to your receiver with Digital Coaxial or Optical. Hope this helps
Posted on Jun 11, 2009
larry james
  • 287 Answers
SOURCE: Onkyo TX-DS555 will not switch to Dolby Digital
regulated voltage to the processor circuit like drop in these onkyo after 8 years. This or a small capacitor fails in this voltage line.
Posted on Jul 16, 2009
  • 5 Answers
SOURCE: Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Posted on Feb 12, 2010
Hi I have just connected my onkyo tx-sr 507 everything works perfectly apart from the monitor channel I have used a composite video cable to one of the inputs on my tv from the monitor output while using...
The 'monitor' video output would go to a corresponding composite video input on the TV/monitor. It would be selected as a source, not a channel. I'm sure the unidentified video device's manual explains it. Any RCA cable would suffice.
Aug 08, 2011 | Onkyo Tx-sr507 A/V Receiver
Onkyo TX DS575x reciever remote problem
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
Nov 17, 2007 | Onkyo TX-DS575 Receiver
I originally did this as a work around for what turned out to definitely be a faulty HDMI card in the reciever and it worked well, you need to go(on the PS3) Settings then scroll down to Display Settings...
It's in the manual of nearly every piece of audio electronics to ensure adequate ventilation.
http://www.retrevo.com/support/Onkyo-TX-SR606-Receivers-manual/id/16690ag612/t/2/
"7. Do not block any ventilation openings. Install in accordance with the manufacturer's instructions."
"18. If you install the apparatus in a built-in installation, such as a bookcase or rack, ensure that there is adequate
ventilation. Leave 20 cm (8") of free space at the top and sides and 10 cm (4") at the rear. The rear edge of the shelf
or board above the apparatus shall be set 10 cm (4") away from the rear panel or wall, creating a flue-like gap for warm air to escape."
But who actually reads the manual?
Jan 26, 2011 | Onkyo TX-SR606 Receiver
I have an onkyo TX-SV515 PRO receiver and the remote speakers will not turn on. The main speakers work fine but when I depress the button to turn on the remote speakers they do not switch on.
I had the same problem. You must turn on the remote speakers via the reciever and then adjust the remote speaker volume control that is only located on the remote control. The volume buttons are on the top right of the remote. It is briefly discussed in the owners manual which can be downloaded online.<!-- from fixya rte -->
Jun 05, 2010 | Onkyo TX-SV525 Receiver
Remote doesn't operate reciever
Hello Fixya customer,
Thank you for your question.
Please determine if the "Audio" button is actually working.... after pressing the audio button, can you still control the DVD, if not then the remote has switched to the Onkyo. Although, this is not 100% conclusive, unless you have a 2nd remote to test the Onkyo with, it provides a sound basis to proceed.
Assuming the remote is transmitting and the IR receiver on the front of the Onkyo is not otherwise blocked, likely faults include the IR receiver, input to the Micro processor, and the Micro processor.
The most probable fault is the IR receiver.
Thank you for using Fixya, and if I can help you further, please let me know.
Apr 29, 2010 | Onkyo TX-DS575 Receiver
Jul 16, 2009 | Onkyo TX-DS555 Receiver
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
TXSR875 reciever display
Hi and welcome to FixYa,
Two possibilities:
  • the Pure Audio feature has been engaged. This turns off the receiver's front panel display;
  • heat related issue. A common fault that develops is component failure, specifically, R9304, a 10 ohms dropping resistor connected inline with the +44V display supply.
Should you be considering a DIY (do-it-yourself) repair, please postback for procedures. Otherwise you may have to seek the services of an authorized service center (specially if under warranty) or a qualified professional
Hope that this be of initial help/idea. Good luck and thank you for using FixYa.
Mar 31, 2009 | Onkyo TX-SR875 Receiver
Remote code for sony playstation 3
hope this helped
please rate well.
Mar 06, 2009 | Onkyo TX-SR606 Receiver
512 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
