Phillips 42PF7220A fix
Hi Inst,
I'm going to bid on a broken Phillips that appears to suffer from the problem you fixed by replacing the upper and lower boards.  You mentioned that you got parts for Vance Baldwin.
Any idea how much those parts cost?  and part numbers?
Thanks,
Bill
    Problem Solver:
  • 12 Answers
I googled the part numbers and ended up on a website that allowed me to purchase the buffer cards for around $120.00 each. The Y sustain card was purchased of of e-bay for $80.00 including shipping. I think that I got lucky with the Y sustain card.
It took a lot of searching to find the cards.
Each card had multiple part numbers on them.
LJ41-02759A = LJ92-01200A = Y Sustain
LJ41-02760A = LJ92-01202A = Y Buffer Upper
LJ41-02761A = LJ92-01203A = Y Buffer Lower
I searched today for the same part numbers and they were priced much higher.
The site was a Vance Baldwin parts store which is where philips must be distributing their replacement parts.
Posted on Nov 20, 2008
    Problem Solver:
  • 7 Answers
Cheap Prices $99.00 each
Y-LOWER BUFFER BOARD 996500032640 LJ41-02761A LJ92-01203A http://hssparts.com/index.php?route=product/product&product_id=1
Y-UPPER BUFFER BOARD 996500032639 LJ41-02760A LJ92-01202A http://hssparts.com/index.php?route=product/product&product_id=2
Posted on Jan 12, 2010
I over bid on an item by mistake. Instead of $2.25 I clicked on $225.00 Ebay is closed at this hour & I can not fix this muself.
your bid only goes .50 cents more than the last bid,it is ok that you bid 225.00,that was the highest you could bid,but,you got it for only 50 cents more than the last bid,dont worry,go back to ebay and view your purchase,it will tell you how much you bid,or paid for it,if the item didnt sell,then you better hope that noone bids on it before the end
Apr 11, 2015 | Computers & Internet
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
I have a phillips 42pf7220a/37 and 7 blink led
The Ymain Board is out if you have the back of the tv exposed disconnect the ymain board and then plug in the tv set and turn it on. the light should remain green and no longer flash. If this happens the Y main and upper and lower buffer boards should be replaced
Jun 15, 2009 | Philips Televison & Video
Vertical lines through the right side of the screen
Sorry sounds like you have a bad panel Try changing picture format if the lines don't dissappear or change bad panel
Apr 17, 2008 | Philips 42PF7220A 42 in. Plasma Television
Phillips 427220a
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Mar 08, 2008 | Philips 42PF7220A 42 in. Plasma Television
Phillips TV- Plasma Model #42PF7220A/37
A tech will need to come out. When the tech do come out have him unplug the Y main and see if the led goes solid greem if it does have them replace the Ymain and the Y upper/lower boards. Most likely that will be the problem.
Feb 29, 2008 | Philips 42PF9630A 42 in. Plasma Television
New glass screen for phillips plasma 42pf7220a/37
Try Callind Tritrtonics in Maryland or Try calling Phillips direct
they should be able to advis you on how to purchase a new screen
Lou Margo
Allied Electronics
loumargo@verizon.net
Jan 23, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
2,868 people viewed this question
Top Televison & Video Experts
