Question about Haier 42EP24S 42 in. EDTV-Ready Plasma Television
Iam needing a 12 pin harness
I put a up grade kit in my haier 42ep24s the control borard tv-5210-39 & z-sus tv-5210-37 board has a flat 12 pin harness with 11 gray wires & one black wire on it and is 12" long that goes from board to board decribed above do you know were i could get this part sears does not have it local tv repair dont know either. need help
  • specter333 Apr 29, 2009
    Ballyb, I have the same problem as dwrom. You seem to know the wiring for the TV, can you tell me if the cable is pinned 1 to 1 or not? Also, what it the name/type of the connector?
    I don't think I could manage to solder the connections since they are spaced so tightly together but I could try to splice two cables together to make one if I could find another cable that uses the same connector.
    Of course the best solution would be to purchase a new cable if anyone has come up with a place to get one. I've tried two place that claimed they were in stock but they couldn't even back order it.
You can order the harness from Haier Company. It cost 12.00 and are in stock.
rmwestr@aol.com
Posted on Nov 24, 2008
  • 26 Answers
The part # for the harness is TV-3363-04. I do not know where you will get this other than from HAIER.
In a worst case scenario, make your own harness by hardwiring (solder) the connections.
On the Z board the black wire goes to connector P2 pin 12. On the CTRL board the black wire goes to connector P10 pin 1.
Posted on Nov 16, 2008
Upgrade kit pdf file
Heard lots of problem with similar case for this tv,you need to buy upgrade kit from the haier itself, there also available at Sears you will get instruction sheet will contain all information all you need is screw driver to replace the parts Control Board TV-5210-39, Y-SUS TV-5210-35, Z-SUSj TV-5210-37, New EPROM Chip 2006 version TV-2455-03, Upgrade Label TV-4050-08 and Haier Service Bulletin SB-TV-0003 containing the instructions to replace the boards yourself.
Good luck..
Sep 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Haier tv video problems
First of all you have to find out whether this unit has been upgraded with a new software or not?
If this unit is upgraded with new software either you have problem in Y-sus board or Z-sus board.
If this unit is having problem for the first time I would recommend to Change the Service Kit
Part number is TV-3940-01.
This kit contains E-prom,Y-sus board, Z-sus board and Control board you have to change these 3 boards together with E-prom IC.
Dont Forget to Rate!
Good Luck
Dals123
Oct 17, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
TV PART
I beleive this comes directly from manufacturer.becasue thsi Kit cotains a upgraed E-prom.
before you order any kit check it this unit has been upgraded before? if this unit upgraded before you dont need to change kit again.
I would say either y-sus or z-sus could be the problem..
anyways chek tis link.. it might help u..
http://www.consumeraffairs.com/homeowners/haier.html
Oct 16, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Upgrade kit part: TV-3940-01 - But the part is backordered for three months. $150.00
Good luck
Dals123
Sep 30, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Plasma tv picture went black
I would say you dont need to repalce Servcie kit.kit is only for 42EP24S units.
examine your unit What is the problem?Is the blue indicator on?If indicator on you will have audio.
In this case I would check first Y-sus board or Z-sus board.
Good luck
Dals123
Sep 28, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
42ep24s Plasma
You may have problem with y-sus or z-sus board.Before conclusion I would say check whether this unit has been upgraded the software or not?
Sep 08, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Please I need a solution to my Haier Plasma TV
Your problem is on the z-sus board. Replace the slow blow fuse (there are two so ohm to find the blown one or replace both) until you can acquire the upgrade kit. I'll need an email address to forward the upgrade instructions and diagrams to unless you know where the board is. You can email me at aviator@ec.rr.com
Apr 18, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Haier Upgrade Kit
In one of my earlier post I posted the phone number where to order the board. However they were on back order so I got lucky an located the upgrade kit on Ebay. I'll post the part number for the kit and boards you need. TV-3940-01 is a kit that contains the following parts:
Control Board – TV-5210-39
Y-Sus – TV-5210-35
Z-Sus – TV-5210-37
EEprom (2006 version) - TV-2455-03
Apr 13, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
The day plasma stopped working
his is what I have found out so far the YSUS PC board1.gif is your problem
Part number 6871QYH045B I have a call into Haier to see if I can get this
I did a search on the web and found a couple but none in the US
so if someone can traslate these sites and help out
http://www.soel.com/view/catalogo/f...278763_&lang=en
It also seems the LG1.gif uses the same board
http://monitor.net****/forum/topic138985-0.html
Jan 16, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Haier 42EP24S 42 in. EDTV-Ready Plasma Television Logo
231 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
