Question about Bernina Artista 180
Lost manual Bernina Sport 108 -need to oil .But where?
Can you help me with direction as to where to oil my bernina machine -Sport 108 Thankyou
  • 202 Answers
Its ok to put a drop or two of oil on any two metal parts that move togeather. Metal gears get grease only and plastic or nylon gears need none at all. Carefull not to over oil as too much will just collect dirt and lint that could cause worse issues.
Posted on Nov 27, 2008
I have been away from sewing for a while but have recently begun again. I have a Bernina 1010. The fabric feeder has quit working. Any trouble shooting tips? I no longer have my manual.
Hm, I'm more familiar with the Berninas older than the 1010. The old mechanicals will seize if they haven't been regularly oiled. Could be the feed dogs on your machine have seized for the same reason.
I've resurrected several seized Berninas from a 930 on down to some 530s by opening the top, side, and bottom and applying a couple drops of oil where metal rubs on metal. After the 830 Record, Bernina stopped including any extensive oiling directions in the owner's manual, even though the 930 requires it frequently. (Some say Bernina really wanted the repeat maintenance business, but the 930 also presented some special issues with the basting stitch and the electronic board.) However, I am uncertain how much a user can oil a 1010 without causing damage. Most Bernina manuals provide information for oiling the race but don't go beyond that. Something that may be worth trying is directing hot air from a handheld hairdryer into the area that houses the feed dogs to see if that loosens anything.
Whatever you do, don't use WD-40, 3-in-1, cooking oil, or anything other than fresh good quality sewing machine oil.
You can find a manual for the 1011 here. It may be close enough to your model to be of some use:
BERNINA Sewing Systems
There are some Yahoo groups whose specialty is the Bernina owner/lover, ie BerninaThirtySomethings, and some others. They are a very helpful and knowledgeable group that could be of assistance to you.
Oct 30, 2016 | Bernina Sewing Machines
Instruction Manual for Bernina 801 - need instructions for oiling the Bernina 801
Hi Jim&Bev, The link below in a 23 page user manual for a Bernina 801 Sewing Machine, I hope this helps.......CHEERS..
Bernina 801 Owner Manual
Apr 16, 2016 | Bernina Sewing Machines
My needle is not movin up or down..switched to zig zag and it moved left and right but no up and down..Im lost without it..whats wrong and how do i fix it? Bernina 1090 s
Have you oiled your Bernina recently/regularly? Consult your owner's manual under the Maintenance section. Sounds like the old oil may have dried and is prohibiting the needle bar from moving. Use good quality (ie Bernina) oil, not 3-in-1, WD-40, cooking oil, or the sewing machine oil from your grandmother's sewing basket). To help free it up, direct heated air from a handheld hairdryer into the interior mechanism of the machine, concentrating on the needle bar area.
Aug 19, 2015 | Bernina Sewing Machines
Hand wheel will not release on my bernina sewing machine what should I do?
If handwheel is difficult to turn manually, it most likely needs cleaning and oiling.
Oct 11, 2012 | Bernina Sewing Machines
I need a manual for a Bernina 830 have lost mine
You can purchase one from this website
http://www.sewingpartsonline.com/instruction-manual-bernina-830---831.aspx
Or you may wish to contact Bernina in your country directly and ask them to sell you one.
http://www.bernina.com/country_search-n111-sEN.html then choose your country.
Jul 21, 2011 | Sewing Machines
Bernina Record 930 Electronic, seldom use, like new. Wheel will not move. Was doing stright sewing, machine slowed down then froze. Maching is clean. No instruction book or manual. Machine belongs to my...
Bernina 930 Records are notorious for the basting stitch sticking which eventually locks up the machine. To prevent this from happening, be sure to run the basting stitch for a few minutes every month. If it is stuck, you'll need to take it to a Bernina technician.
If it is not the basting stitch, it could be a broken plastic gear (trip to the Bernina technician) or it needs oiling.
If it is not a broken gear, then it probably needs oiling. Your Bernina mechanical requires regular oiling and cleaning even if you don't use it (ie, every time you change the bobbin, every 8 hours of sewing, or every 6 months if not in use). HINT: recommend Bernina oil or similar good quality oil for mechanical machines, NOT 3-in-1 oil, WD-40, or cooking oil!!! One or two drops of oil in every oil hole and every place that metal part rubs against metal part.
Treat your Bernina well and it will serve you well for many years.
Oct 23, 2009 | Bernina Sewing Machines
I have bernina sport 801 machine and need to know
You can oil any two metal parts that move togeather or through each other. Do not oil bearings and do not oil gears. Do not use 3 in 1 oil or WD-40. Use regular sewing machine oil.
801's were made from 1979 - 1982. The way Bernina dated these on the machine is by the serial number. Your number would probably start with a 0 or a 1. 1970 is a 0, 1971 is 01, 1980 is 1, 1981 is 11, 1990 is 2, 1991 is 21 etc. etc.
Rick
Sep 20, 2009 | Bernina Sewing Machines
Sewing Machines Logo
239 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
