Question about Toshiba Satellite A100-S8111TD Notebook
My mouse buttons on laptop are very loose
Hi, ive been on my laptop most of today.
I notice that the left mouse button on laptop clicks too much and seems to be loose.
I have to press quite hard, if I press lighty it makes very light clicking noise.
Why is that?
Dont want to wear out the left button.
  • soniadeygun Nov 14, 2008
    Thanks for your help!!!
    Sonia
    Scholar:
  • 121 Answers
It looks like you have broken plastic grove that holds the button to place...and this is giving you the clicking sound...
if you don't to use an external mouse....you will need to take it to repair center ...if you think you are capable of opening the top cover of you notebook without problem....let me know...
Cheers
Posted on Nov 14, 2008
Asus K52F Left Mouse button Broke
One other thing you can try is a can of compressed air attach supplied straw, lift left button with fingernail give good few blasts of compressed air in the crevice to clean out any dust and dirt, some people dismantle the laptop for easier cleaning.
Jul 09, 2012 | ASUS (W2JBY007MDVDRW) Notebook
HOw to replace the mouse left click and right click
The mouse click changes are based on OS used.
In windows OS ..Click Start button on your windows desktop. Select and click on Control Panel from the menu. Select and click Mouse from the control panel. From the Mouse Properties Window, select the Buttons tab. Select and check the Switch Primary and Secondary Buttons check box. Click the OK button.
Your mouse buttons should now be switched around, so now when you click your left mouse button, it will behave as a right-click, and clicking your right mouse button will behave as a left click.
Dec 01, 2010 | HP Compaq Presario C306US Notebook
How do i can et internet on my laptop xp to connect from wireless router it show a lock how can i unlock
Step 2: With the left mouse button, click on 'Control Panel'.
Step 3: With the left mouse button, click on 'Network and Internet Connections' (Network Connections, if in Classic View).
Step 4: With the left mouse button, click on 'Network Connections'.
Step 5: With the right mouse button, click on the 'Wireless Network Connection'.
Step 6: With the left mouse button, click on 'Properties' button.
Step 7: With the left mouse button, click on the 'Wireless Networks' tab.
Step 8: With the left mouse button, click on the name of the wireless network, under 'Preferred networks', that you want to automatically connect to.
Step 9: With the left mouse button, click on the 'Properties' button.
Step 10: With the left mouse button, click on the 'Connection' tab.
Step 11: Ensure there is a checkmark in the checkbox, next to'Connect when this network is in range'.
Step 12: With the left mouse button, click on the 'OK' button.
Step 13: With the left mouse button, click on the 'Advanced' button.
Step 14: With the left mouse button, click to select 'Access point (infrastructure) networks only ' (This will help prevent your connection from bouncing around from one network to another).
Step 15: With the left mouse button, click on the 'Close' button.
Step 16: With the left mouse button, click on the 'OK' button.
Jun 13, 2010 | Computers & Internet
Left mouse button stuck down
The same thing is happening with my mouse button. I disassembled the computer to get at the mouse and noticed that there is a rubber ball cover to the button . If that ball gets damaged in any way it appears to cause it to lose the clicky feeling of the button and causes that button to sit a bit lower than it should. Not a real easy fix.
Sep 02, 2009 | Dell XPS M1530 Laptop
Loose left button mouse on an hp dv4-1120us
If only the one button is loose then touch pad assembly probably will require replacement. This isn't a big job but usually involves opening the case. Two screws and one connector and button it back up. If the laptop is new you should have this covered by warranty. Cost of the part should be about $30-$70 as well as labor.
If you are lucky you might just have a loose fitting button that you can snap back in to place. With the laptop off try to gently push/wiggle the button down. It might pop back into its mounts. If this works (slight chance) then it might work normally for a while and pop out again. It won't have fixed the wear that let it come loose.
Aug 17, 2009 | HP Pavilion DV4-1120US Laptop
Laptop Acer Travelmate 2300 Sticky Left mouse button HELP!
If you have the disk remove/reinstall the mouse
no disk , search the make and model
No mention of which OS your using so let me know if you need more assistance
If your using XP try this
Go to start
control panel
add/remove
device
remove
reboot
reinstall
Hope this helps , let me know outcome thanks
Jul 13, 2008 | Acer TravelMate 2300 Notebook
MX Revolution left click problem
Try a bit of compressed air - perhaps dirt is jammed under the button.
If its under warranty you might want to return it to where you bought it.
Feb 27, 2008 | Logitech MX Revolution 931689 Mouse
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Toshiba Satellite A100-S8111TD Notebook Logo
438 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
