Question about Compaq Presario 1200 Notebook
Computer shut off without warning.
Bottom of laptop became very hot before the laptop shut off, just as though someone had unplugged it. It did not go through the shutdown sequence. Just lost its power instantly and will not come back on. Does it need a new battery?
  • eecom May 11, 2010
    Hi Compaq user. When you say it will not come back on, do you mean the laptop will not work at all now? Or did you manage to boot it up again later?
    One way to check if the battery is at fault is by 1) removing the battery, and 2) plugging your laptop directly into the mains (if you haven't tried this already of course :))
    Master:
  • 569 Answers
I think it is also a problem of overheating
you get it checked up with the service center there might be the problem with the motherboard also
Posted on Nov 16, 2008
My computer shuts down without any warning at all. The problem has occurred 4 times this week when charger is unplugged but power icon still shows me approximately 50% battery. Sometimes computer lets me...
Check you power settings. It is possible that it is set to shut down at 50% battery power.
If it is overheating, that too will cause a shutdown. What is happening at the time of shut down? Are the vents on the laptop being blocked in any way?
Sep 04, 2011 | ASUS Computer International U35jc A1...
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Solution:
May 04, 2010 | Toshiba Computers & Internet
It seem to be getting warm then shuts off and it need to cool off for a hour then works fine until get hot again
Most laptop related heat problems are due to clogged up fans. You have open ventilation holes in the back sides and bottom of a laptop. Using an air can (don't shake it) unplug the laptop remove the battery then blow out all the open holes. Also, try running without the battery to see if maybe the battery is overheating. Hope this helps.
Oct 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
Laptop shuts down
if it just shuts down suddenly without logging off and doing a normal windows shutdown, you probably have heat issues to to dust clogging your heatsink. Using an air compressor at 80 lbs (canned air won't have enough pressure), blast air into the opening/grille where hot air is exhausted from the laptop. this will likely shoot a cloud of dust out of the bottom of the laptop. Shoot air into the fan intake on the bottom of the laptop next. If the laptop still shuts down suddenly, check that the fan is actually working (feel hot air blowing?) - maybe the fan is dead.
hope this helps! Let me know.
Aug 08, 2009 | Computers & Internet
Computer shuts down without warning
My first guess is that your laptop is over heating. Even with a fan underneath, if the bottom vent is clogged with dust, the CPU will still get too hot. Does your computer last longer when you run less programs? I would check for dust around the fan inside your laptop. There's a video on youtube showing an acer being disassembled:
Although it may not be your laptop specifically, hopefully it will head you in right direction. It would be a bad idea to blow the dust further back into your computer, so you may have to loosen some screws and buy a electronics duster from an office supply store, but it should solve the problem. I've ran into this a lot over the years, specifically with Acer and Dell computers. Hope this helps!
Jul 14, 2009 | Computers & Internet
Gateway notebook m1624-shuts off randomly by itself
Check if your laptop is hot on the bottom left corner. If it is hot that means that the cpu thermal past is dry out. I have to sent in to gateway 5 times for the same shut down problem while it was still in warranty. The gateway m-1624 has a poor cooling unit. I hope that help you.
Jun 21, 2009 | Gateway Computers & Internet
Compaq NX6120 - heat issue computer shutting down without warning
All you can do short of upgrading the fans is to either buy a laptop cooling pad or make sure when you are using it that all vents are free. Hope this helps.
Jan 10, 2009 | Compaq Audio card Sound Card
HP Laptop (with Windows XP) that won't boot up properly.
Check you havent accidently knocked the RAM.
You may have put the the fan in the wrong plug.
e-mail me photos of the mother board or wherever the fan was.
completleywacked@gmail.com
Jun 29, 2008 | Computers & Internet
Compaq Presario 1200 Notebook Logo
55 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
