Question about Jenn-Air JGS8850BDS Stainless steel Gas Kitchen Range
How do I replace my burner igniter?
I have a Jenn-Air JGS8850BDS Stainless steel Gas Kitchen Range with an igniter that I need to replace.
5 Suggested Answers
  • 58 Answers
SOURCE: gas range igniters won't shut off
The problem that you're describing is commonly associated with the spark modulator. It usually occurs after a spill or when the ignitor electrodes have remained wet after a cleaning. If after a day or two it continues to spark intermittently on its own, then the only recourse would be to replace the module. Hope this helps,,,, Bill
Posted on May 28, 2009
SOURCE: How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Posted on Oct 11, 2009
SOURCE: Does anyone know where i can get an instruction on
I just replaced the panel overlay on my stove and that did fix the problem (of the 3,6,9 buttons not working). I found the part for under $110 on line and replaced it myself.
Posted on Nov 05, 2009
Macmarkus
  • 2605 Answers
SOURCE: Jenn Air gas range- burner not fully lit
Can you verify which burner it is that won`t ignite/burn properly ?
I should be able to help, but I just need some clarity. I`ll watch for your reply.
macmarkus :)
Posted on Jan 24, 2010
  • 2364 Answers
SOURCE: Several Gas Burner Igniters spark every 5 seconds
hi could be a short on the ignition switch of the spark box is stuck in the repeat mode disconnet power and see if this helps
Posted on Feb 09, 2010
Can you convert this oven from natural gas to propane?
Yes - I believe it comes with the new jets that you need to change out. Not that hard to do really; we did it ourselves.
Oct 11, 2010 | Jenn-Air JGS8850BDS Stainless steel Gas...
6 buttons on my control panel do not work.
Possible failure of the control panel, possible failure of the lead cord.
There can be dirt accumulation for the contact loss or a failure due to prolonged use.
Replacement is the only other option if cleaning does not work.
Sep 24, 2010 | Jenn-Air JGS8850BDS Stainless steel Gas...
Ignitor for burner not working
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 02, 2010 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Oven flame will not go on. Broiler flame working
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
May 31, 2010 | Jenn-Air JGS8850BDS Stainless steel Gas...
Does anyone know where i can get an instruction on how to replace the touchpad on a Jenn Air JGS8850BDS gas range/stove? hhkk_kh@yahoo.com
Nov 05, 2009 | Jenn-Air JGS8850BDS Stainless steel Gas...
Problem with getting burner to light.
All my ignitors spark when I turn one of them on. I'v been told it is normal. I had a problem before and the tech that replace the ignitor said the issues is with alignment. Try to rotate the burner a bit left or right and see if it fixes it.
Aug 26, 2008 | Jenn-Air JGS8850BDS Stainless steel Gas...
Ignition "clicks" forever
If only one out of the surface burners clicking, rotate the cap perhaps it doesnt sit properly,or check the electrode if broken replace it.
If it was all surface burners clicking. replace your spark module
Jul 22, 2008 | Jenn-Air JGS8750BDS Stainless Steel Gas...
Jenn-Air JGS8850BDS Stainless steel Gas Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
