Question about Foxconn 6627MA-RS2H Motherboard
Foxconn n15235 motherboard WIN XP 0x0000007f exception error
Processor is a Pentium. Exception error occurs after boot when the XP "one tooth monkey" screen, passes by twice, then blue screens with the WIN XP 0x0000007f exception error (Kernel/Intel problem)
  • 781 Answers
Try reinstalling windows in repair mode
Posted on Nov 14, 2008
Virtual mode exception error
7 Beeps: Virtual mode exception error
Explanation: Virtual mode is one of the different modes that the processor can run in. The system is reporting an error when testing this mode.
Diagnosis: There is a problem related to the processor or motherboard. Note that this doesn't mean that the processor is necessarily dead, since the system won't boot at all with a dead processor.
Recommendation:
Troubleshoot the processor.
Troubleshoot the motherboard.
PCGuide TSX Troubleshooting the Processor PCGuide TSX Motherboard General Failures
Jul 09, 2014 | MSI Computers & Internet
Windows XP sp3 not booting Error system halted
Is your First Boot Device in BIOS is Set to Hard Drive? IF not then Just Change it Hard Drive.
Aug 11, 2012 | Intel Computers & Internet
Dear Sir I am installaing WIn Xp Professional 64 bit on Intel motherbaord DH 61 WW with 8 GB corsair ram and after the boot hardaware error occurs and its ask to check the hardware or viruses...
The motherboard has nothing to do with your problem. Its your processor it has to be a 64 bit processor. If you don't during the installation you will get an hardware error. Your windows 7 must of been a 32bit or aka 86x platform. So put windows 7 back on (recommended) or try windows xp pro 32bit
Aug 11, 2011 | Intel Desktop Board DH61WW Classic Series...
ONN N15235 motherboard, which is a 775 socket. I am currently running a Pentium E2160 on its but its pretty slow so I bought an E5400 to replace it. When I changed the CPU over and started up my computer...
The LGA 775 processor socket doesn't matter, calderwooddu.
It's up to the motherboard chipset, and the BIOS program, and version, of what that Foxconn N15235 will support. I would go back to the Pentium Dual Core E2160, use CPU-Z from CPUID.com, (Free), and see what the motherboard chipset is, first.
(Motherboard chipset: The Northbridge, and Southbridge chips. Chip is slang for I.C. Integrated Circuit)
The Northbridge chip is what determines what Processors are supported.
1) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
2) http://en.wikipedia.org/wiki/Northbridge_%28computing%29
Since the E2160 is built upon the 65nm technology, and the E5400 is built upon the 45nm technology, the Northbridge chip of the Foxconn N15235 may not support the E5400.
With the technology change are also Instruction Set changes. Plus other parameter changes. The BIOS program, and version on the Foxconn N15235 may not support these, either. Sorry to be a bummer.
Not a solution per se, Yet.
Need to know what computer this Foxconn mobo is out of. (MOtherBOard)
OR, if you get the computer operational again, let's use CPU-Z to see what the motherboard chipset is.
Need help in downloading, and/or installing CPU-Z, post in a Comment.
Oct 09, 2010 | Computers & Internet
Win xp 945gz7mc n15235 doesent work the LAN Realtek RTL8101
Download from the home page:
http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000201
Sep 10, 2010 | Foxconn 945GZ7MC-RS2H Motherboard
My board does not turn on and its beeping. Ive counted 7 beeps. i tried replacing the memory with known good ones but still the beeping persist.
MSI states that 7 beeps means "Virtual mode exception error "
Not knowing the price of either your processor or the board it is hard to say what to do for the best
Good luck
AMI Beep Code Deep Code Description 1 short DRAMS refresh failure 2 short Parity circuit failure 3 short Base 64k RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed AWARD Beep Code Deep Code Description 1 Long, 2 Short A video error has occurred and the BIOS cannot intialize the video screen to display any additional information
Jun 19, 2010 | MSI K9N6PGM2-V Motherboard
Is it support pentium 4 for foxconn motherboard n15235
This is a socket 775 boards and it should support Pentium 4 processors. TC
Mar 24, 2009 | Computers & Internet
Foxconn board
the problem is software, there is nothing wrong with the processor as the machine boots showing that the processor works, have a look at your memory and clean it.
This problem occurs because there is a limited amount of kernel space available for kernel drivers so there is not enough stack space for processing the exception. its an operating system problem, try and boot into safe mode and perform a system restore by pressing F8 on boot up
good luck
Nov 14, 2008 | Foxconn Computers & Internet
I HAVE fOXCONN N15235 MOTHERBORD
Hi.I am Adrian.I need drivers for win.xp
Sep 19, 2008 | Foxconn 6627MA-RS2H Motherboard
Drivers placa base Foxconn N15235
Foxconn drivers can be found at this webpage: Driver Update Software for XP Vista 7 8. Use their software to update all of your drivers.
Wish you best of luck
Hans
Sep 09, 2008 | Foxconn 6627MA-RS2H Motherboard
Foxconn 6627MA-RS2H Motherboard Logo
1,056 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
